Results 1 to 10 of 10
Thread: urgent coolant issue
    Jun 2006
    Hornsby
    spoke to matt earlier ( tar brother )
    is there anyway to stop the coolant driping on to my foot well so that im dont lose coolant- im going through heaps , i just need a quick fix till i can get under it this wknd any suggestions
    sydney
    if its leeking from the heater matrix which it probably is just put a u bend in the enginebay side of the coolant pipe(the two pipes that travel through the firewall off the gearbox side of the motor), its summer now so you dont need a heater. i did on my car a year ago and still havent fixed the heater
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    syncro Guest
    Just buy a length of generic hose from Repco, Supercheap etc and join the two pipes together as a temp.
    Jun 2006
    Hornsby
    cool im going to go look at it now so i should be able to see two hoses going into the firewall ?
    Jun 2006
    Hornsby
    to easy lads my old man will get me a u bend and ill temp it up im gunna do a dash swap anyway thus i can rip out the ****y matting behind - lucky i got no carpet in
    ps ill do a write up cos we need to get a DIY thread thingo going in the mk2 section
    peace
    tom
    Oct 2006
    sydney
    i remember i had a hack saw and no pipe so i saw a chair in the workshop with the metal legs and used a section of pipe it is still working
    Jun 2006
    Hornsby
    haha ghetto stlye
    Jul 2005
    heater cores
    Not only golf2's but I've had a run of golf 3's with the same problem(mainly vr6's).
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Camden, Sydney
    At least a Golf 2 dash comes out a bit easier than a Golf 3 one!
    Feb 2006
    Melborune, VIC
    You don't need to remove the dash to remove the heater matrix on a Mk2.
Similar Threads
  1. You need to know this about coolant..intersting VAG fact...
    By pommy_golfer in forum Mk3 Golf & Vento
    Last Post: 09-07-2007, 10:00 PM
  2. Disappearing coolant on Golf 2.0 TDI
    By dieselcar in forum Mk5 Golf & Jetta
    Last Post: 16-01-2007, 01:41 PM
  3. What The Coolant ???
    By sikdub in forum Mk3 Golf & Vento
    Last Post: 11-10-2006, 01:42 PM
  4. advice: what coolant to use
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 01-07-2006, 04:40 PM
