Originally Posted by
Elmura
I run the recommended pressures as per the digital display on the MY12 CC - 290 kpa cold. Get this... 42psi!!
I've never had a car run this pressure before (I'm early 40s) so this surprised me & I had to double check. And this is for the Part Load setting!
Sent from my LG-D802 using Tapatalk
Hi Elmura,
Wow, your recommended pressures sound really high, especially for part loading! Are you running 42psi all round?
42psi cold would mean around 45psi once the tyres warm up, which I'd imagine would probably make the ride noticeably harsh, even with suspension set to "Comfort".
Maybe your tires are a different size to mine? I've got the standard factory "Lakeville" rims with Continental Contisportcontact 5 tires 235/40 R18 95W Extra Load.
The MFD on my CC displays a recommended pressure of 38psi fronts and 35psi rears part loaded. No issues with tire wear, handling or ride quality at these pressures. If anything the ride is a bit quieter over the coarse chip roads we have plenty of here in WA.
The only time I've run higher pressures was when the missus, myself and another couple went on a road trip from Perth to Sydney, Jindabyne via Canberra, The Alpine Way, Thredbo, Melbourne, Mt Gambier via Great Ocean Rd, Adelaide and back to Perth. The CC was fully loaded with four ppl + luggage + munchies + water too.
I ran the fronts at 42psi and rears at 39psi for the duration of the trip and it was perfectly fine. Ride was compliant, tires wore evenly, no issues whatsoever.
On a side note, I was pretty stoked to get at least 1200km out on the open road from a single tank of diesel before the fuel warning light came on, which is fantastic when blitzing the stretch between Norseman WA and Ceduna SA and back across the Nullabor.
1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
