believe the cheaper versions i/e tdi and 4 cyl use the ABS sensors whereas the V6 and R36 uses sensors in the wheels i.e you can get a readout of tire pressure rather than a warning. Doesn't the manual go into further detail?
VW dealers, head office, no one seems to know. Does anyone know whether its direct (Using sensors in the wheel) or indirect (Using ABS speed sensors to determine pressure)?
2010 Passat CC TDI | Sat Nav | RVC | Park Assist | Active Seats | Adaptive Cruise | Fiscon Basic Plus | H&R Sports | 19" Kahn RSC 2-Piece
B6 Passat Wagon No KESSY
This is actually something I was thinking about just a couple of days ago. When I did a drive from Melbourne to Canberra with a FULLY loaded car, I changed the pressures in the R36 to be the higher load pressures and when I unloaded the car in Canberra set them back to the low load.
Now I set the low pressures in the tyres before changing the setting in the TPMS back to monitor the lower pressures. As soon as I turned the car on, I got a warning from the TPMS that the pressures were too low. That to me indicates the TPMS in my car is based on pressure sensors in the valves rather than rolling diametre. As soon as I changed the TPMS to monitor the lower setting, not more warning.
I can confirm that the CC uses sensors in the wheels (Pulled the tyre off my spare)...
So much for the 3 Vic VW service departments who said TPMS is run off the ABS speed sensors![]()
Sorry if this is an old thread.
The visual difference is the tyre valves. Volkswagen Tyre Pressure Monitoring System (TPMS)![]()
Golf GTD (170) 2010, 5 Door, Shadow Blue, Flat Tyre Indicator, Service Plan, Basic Protection Pack + VCDS.
Going to give this thread one hell of a bump but I'm at odds with my tpms.. I have the V6 CC and the valve stems that suggest my car has a direct system. Should I be able to view pressures on the mfd? The only thing it does is give me a warning to 'check tyre pressures' when I start the car, or if the pressure is really low I get the warning light. The reset button in the glovebox does nothing and I have the partly/fully loaded monitoring button on the centre console. After reading above it seems that VWA might not be able to help me out here. Is anyone aware of a way to check using VCDS?
CC's use individual sensors, I've got a 2009 and this is the case, we also have a 2006 Jetta which uses the abs wheel speed sensors to determine if there is a flat. In this system a slower spinning wheel to the other 3 will throw the flat tyre warning.
The newest tpms system gives you a pressure reading for each tyre, if you don't see the picture of the car with the readings on the mfd then you have the basic system.
From past experience I found the sensor based system to be very accurate, it picked up a slow leak before I noticed it as the tyre looked fine.
With your issue above are you 100% sure you filled he tyres up to the correct KPA rating front and rear for the partially loaded ratings? Maybe you have a faulty sensor if this is the case
Ok so no, I don't have the car with the individual pressures so it must be the basic system then, thanks for clearing that up for me. I don't actually have any issues just wasn't sure whether it was functioning correctly. I usually pump up to 38-40 psi depending on what type of driving I'm doing and everything functions as it should (light goes out, no warning on mfd)
My CC uses individual sensors. Had a wheel alignment, rotation and balance done at BJ's the other day, told them to put 38psi Front and 35psi rear. Saw them pump the tires after the rotation, asked the tech if he'd put the pressures I'd requested on front and back and he said yes. The MFD was live, so I asked him to check by selecting two screens to the left of the digital speedo. 40psi all round. His excuse? It's their "standard" inflation pressures. Sheesh.
1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
I run the recommended pressures as per the digital display on the MY12 CC - 290 kpa cold. Get this... 42psi!!
I've never had a car run this pressure before (I'm early 40s) so this surprised me & I had to double check. And this is for the Part Load setting!
Sent from my LG-D802 using Tapatalk
