VCDS tweak: Low-beam+Parker for Incandescent headlights
If your mk7 has incandescent headlights (like mine), then you probably have observed that the front parking lights are not illuminated when the low-beam lamps are switched-on. What happens (at least on my mk7) is that the DRL/parker filament (15 Watt) in the "inner lamp" switches-off when the low-beam switches-on!
So, here's a (simple) VCDS tweak that modifies the behaviour of the DRL/Parker filament in the "inner" front light so that it illuminates with the low-beam headlight. Diagrammatically, the effect is as shown in the picture below. The illumination level of the "inner" light will be whatever setting is used for the parking light (i.e. the setting for the Dimmwert EF adaptation channel)
http://www.vwwatercooled.com.au/foru...4B3Pgpng-2.jpg
Instructions (note the table below shows the new "Object tags" in the latest VCDS software)
- Select 09 - Central Electr control module
- Select Security Access - 16 from the "Open Controller" screen
- Enter the magic number 31347 and return to the "Open Controller" screen
- Select Adaptation - 10 from the "Open Controller" screen
- From the pull-down button check that the default values for the adaptation channels are as shown in the table below for Existing Setting column
- Change the 2 x adaptation channels depicted in the table below to the values in the New Setting column (use the "Search" box to locate the correct channels)
- Optional: If a different illumination level is desired for the "inner" lamps for the parking light function, alter the settings for:
- ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 and
- ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5.
Note: any change made will also apply to the Single-Sided-Parking-light function.
http://www.vwwatercooled.com.au/foru...i33Yupng-2.jpg
Note: I make no judgement regarding the compliance (or otherwise) of this tweak with the Australian Design Rules. Forum colleagues should satisfy themselves in this regard before implementing these instructions.
How to find hidden features... ?
I want to activate the Performance Monitor in my ( 2016 ) Golf-7 ALLTRACK 1.8 TSI ?
Link: https://www.youtube.com/watch?v=nvHs_iDUN9k&app=desktop
I have VCDS
How to do it ?
