Courtesy of DV52
http://www.vwwatercooled.com.au/foru...3f534534-1.jpg
Sent from my SGP712 using Tapatalk
Printable View
Courtesy of DV52
Thanks Polar B: But just to be clear - the tweak instructions aren't mine. They were first provided by DMC on VWVortex (see HERE.) My apology to DMC for my failure to acknowledge the original author on the ODB11 forum.
PS: also, please ignore the "moderator" status - it was greatly exaggerated and I'm hoping that I will get-back my "new-member" status soon
Good afternoon , my name is Martin and I am new to the forum . I'm in Mexico , I have a GTI7 and have some doubts about the use of vag com .
wanted to know if it is possible to increase the rpm to put the sport as well as the audi s3 new . sorry for my English but esty using a translator . Thank you
No....
Eaglehawk: don't get me wrong- I reckon that you are entirely correct, but the mk7 (mine at least) has a real interesting adaptation channel in the CAN Gateway control module (hex19) with the descriptor Increase idle speed request. The allowable entries are Mode not active (factory default), no request, stage 1, stage 2, stage 3.
I've not played with this channel, so I'm not sure what it does - perhaps someone else can comment?
http://www.vwwatercooled.com.au/foru...6e899dc9-1.jpghttp://www.vwwatercooled.com.au/foru...7e184f69-1.jpg
I've got a MY16 and I leave the mirror control knob on L, and it seems I have the hardware installed in OBDeleven. Is the passenger mirror supposed to dip as soon as I put her in reverse? I swear that isn't happening but I'll stare at it in the morning [emoji3]
You actually need to set the mirror to the position you want it to dip to.
Follow these steps:
1. Set knob back to 0
2. Put car in reverse.
3. Set knob to L
4. Adjust mirror to the dipped position you want.
5. Test this has worked by turning the knob back to 0, the mirror should return to driving position.
6. Turn the knob back to L, the mirror should dip to your set position again.
If you leave the knob on L, the mirror will stay dipped for a little while when you go from R to D. It will return to normal position after you drive forward for a bit. It will automatically go to dipped position the moment you go to R.
Isaacinsoll: What agenttumb is saying is entirely correct if your car has the steering wheel on the right-hand side of the car. Most folk here are from Australia, but I note that you haven't indicated your country on your information panel (albeit the piture of the mirror switch on your post does look like a RHD car)
Anyhow, if you are not from these parts and your steering wheel is on the left-side of the car, Simply replace "L" with "R" in Agentthumb's instructions.
PS: Have you enabled Mirror Dip in the menu ?
Press CAR button, then select Setup from the lower RH screen (looks like a cog), then select Mirrors and wipers, then enable Mirror Dip
