Hello =) Need some help. Does any have coding of ESP from MY16 with 3Q0907379 unit? =)
Printable View
My coding unit ABS/ESP after Retrofit 5Q0 to 3Q0
http://www.vwwatercooled.com.au/foru...bf22a5f7-1.jpg
Regards
zloybob
Information from my database below
;SW:3Q0-907-379-F HW:3Q0-907-379-F --- ABS Brakes
Coding:01FA93A13421097407770603C1C8A980C92C90E0608 395F514605078C006
EV_Brake1UDSContiMK100IPB
;SW:3Q0-907-379-P HW:3Q0-907-379-C --- ABS Brakes
Coding:04FA6AA12420096E0078020981C4252056249000408 1A4B210630050C002
;EV_Brake1UDSContiMK100ESP
SW:3Q0-907-379-R HW:3Q0-907-379-G --- ABS Brakes
Coding:04FA8AA12421116C077C060941CB2920512488E0608 294F31822503AC282
;SW:3Q0-907-379-T HW:3Q0-907-379-C --- ABS Brakes
Coding:01FA6BA154200971007C020941C76880D62A9000408 216B6144350D3C089
Coding:01FA6AA1242509720078020081CC298056249000408 194B410430050C002
Agentthumb and Dv52, thanks. I just had to follow those steps above and it worked perfectly [emoji3]
Coding Gurus, need some help
I'm using OBDEleven and not a RT dongle and have been using the instructions off DV52 post. So far I can successfully achieve all the changes needed except that i cannot change adapaion channel 4 to "brake light" from post #614.
Imgur: The most awesome images on the Internet
Is this a ODBEleven issue or i am just blind?? http://www.vwwatercooled.com.au/forums/
Thanks in advance
Hi, Dose someone know how to change Discover Pro Start up screen as below ?
If possible I would change My car photo too.
Discover Pro MIB1 Custom startup
https://www.youtube.com/watch?v=82Hq44q-uQo
Polar B: Hi. Yes, it probably is an OBD11 issue! The thing about how OBD11 reports adaptation channels is that it uses a parent-child structure whereas VCDS uses a " flat" naming structure - starting with a parenthesis number for Leuchte-sets.
The other thing about OBD11 is that it reports adaptation channels mostly in German and I suspect that this is the major reason for your inability to alter "channel 4 ". My instruction says change this channel to Brake light (using VCDS) - so, in German, this translates to Bremslicht (see picture below - note: the screen shot is NOT for the adaptation channel in my instructions - but hopefully it demonstrates my point)
My advice - whenever you are using VCDS instructions on OBD11 - have a copy of Google-translate open as well!
http://www.vwwatercooled.com.au/foru...yHRGCpng-2.jpg
ZEAL san: Hi. Wild guess - entirely untested, but there's an adaptation channel in MIBI titled
(7)-Startup_Screen_Sticker_HMI-Start screen China
it has the default setting VW Import which I think gives the VW symbol on start-up. I note that this screen is missing from your video, so I assume that "VW import" has been replaced by a personalised file - not sure how though. Perhaps someone else here can explain
Don san, thanks for your reply.
I am interesting how to import pictute file on this setting.
When I checked my channel map of STG 5F, my setting is
Startup_Screen_Sticker_HMI 00 00
I am not sure how to change on this number to import the picture file.
Thank you.
