Originally Posted by
DV52
Hello again. I assume that you are referring to bobcrusader's tweak for DRL wink FOR FITTINGS WITH LED DRLs ONLY? I've just checked the instructions and I would have done it slightly different (I would have altered the priority between the wink and the parking light alpha-pairs, but my way would have been more complicated). Anyhow, bob's instructions look OK (IMO) and I've had no reports for other forum colleagues.
Without wishing to infer anything about the veracity of your changes (and assuming that you do have LED DRLs), have you considered examining the Codinglog.txt file that lives in the Ross Tech/debug subdirectory on the laptop that you use with your VCDS cable? It's a simple txt file, so you can open it with almost any text reader. Have a close look at the records in the file that pertain to the tweak and confirm that you made the changers that you thought you made.
