@Hillbilly: for both the "technically challenged" and for the technically unchallenged - it does indeed mean the same thing; "it means that a light appears on the dash in concert with the brake lights"
Printable View
Yeah I realise that(was just joking) and cant find the "Tail lights" in the adaptations in G15 on just looking before I plug into car Maybe its in German???
I can find Bremslicht which is the closest I can find to Google translator
Brake lamps= Bremslichter
Or Brake lamp= Bremslicht
Have done all that and it works but I seem to have a new green icon in the dash for "Press foot brake" . When I do so the light as said above comes on and the light on the dash goes out and comes on again when I lift my foot off brake. It is immediately above the ACC symbols and slightly to the left of it.. Dont remember seeing it before?????????????
@Hillbilly: yes, VCDS reports the setting as "Brake lamp" and OBD11 calls it "Bremslicht". Not sure about "Press foot brake" because I don't know your car. But I suspect that the message was always there - the tweak doesn't change anything on the hex17 module.
@Hillbilly: clearly I can't dissuade you from believing your suspicions - so I won't try. If you can be swayed by the brutal logic of a wiring diagram, then the arrangement below should be compelling. It shows that the hazard warning light is controlled ONLY by J519 - which is the module that VCDS calls "BCM" and OBD11 calls "Central electrics".
As I have said - nothing in the tweak impacts on the hex 17 module (the dashboard/instrument cluster)
https://www.vwwatercooled.com.au/for...EasYrpng-1.jpg
Well results from todays drive are extremely inconclusive as my hazard button is in a position that is constantly in sunlight and therefore impossible to tell if its lit or not. So while the mod works its virtually useless on sunny days.
Havent figured out the handbrake message yet but the icon goes away when I start moving..
Hope someone can help me with this? Does anyone know how to change this white (the one above temperature) line to blue?
Where can I change this with VCDS?
White:
https://www.vwwatercooled.com.au/for...Whitepng-1.jpg
Blue:
https://www.vwwatercooled.com.au/for.../Bluepng-1.jpg
Hope anyone can help, thanks!
