Hi Don
Is there a way to activate the SafeLock function?
No one can open or unlock the door from inside of the car if the car is locked.
Thanks
Printable View
As Rainesh correctly advises the facility is enabled/disabled by either:
For mk7 Golf
In BCM (@ address hex09)> Coding
http://www.vwwatercooled.com.au/foru...v67lpng1-1.jpg
For mk7.5
In BCM (@ address hex09) > Security Access -enter magic number, 31347 > Adaptation> ENG10579-ENG10924-ZV allgemein-ZV_ohne_Safe_Funktion change to "not installed"
BUT (and there is always a "but"), the Wiring Diagram for those mk7s that are fitted with "deadlocks" (SAFELOCK) appear to have an additional motor in the door lock unit.
See pic below:
http://www.vwwatercooled.com.au/foru...c6hXipng-1.jpg
So - it's unfortunately more than just a coding change
Hello community, I ask if any of you would help me to find the items to activate the automatic closing of the windows in case of rain in a Golf MK7 2013.
I have performed the procedure of DV52 (Link: VCDS (VAG-COM) codes and programmable options for Golf Mk7) that in the first items everything is ok while as I enter Codink I can not find the entries:
http://www.vwwatercooled.com.au/foru.../2hezxo7-1.jpg
So far everything is ok.
From here on I can not find the rumors:
-Access control 2-Regenschliessen_ein_aus.
-Access control 2-Regenschliessen_art
These are my entries in Access Control 2:
http://www.vwwatercooled.com.au/foru...5yng9png-1.jpg
Thank You!!!
Me
As others have mentioned, only the outer clusters have turn signals in them (therefore not offering another section of light to counter-flash the outer lights).
What I want to know is if there’s a way to activate the LEDs on the boot lid cluster (that line up with the outer brake lights) to light up as brake lights (similar to those on the Mk7 LED lights), and if there’s a way for the brake light to act as a turn signal?
Maca: In respect of your second question I'm almost certain that it is possible - whether it's road legal to have this US style operation of the outer brake lights is of course an entirely different question. If you can post-up an adaptation channel map from your BCM, I will have a look and make a suggestion.
