Sorry for the late reply Don.
Thank you for your answers.
I own a Passat and I tried to find those settings in the BCM but Failed.
Neither yours or Rainesh's showing up in my Passat.
Neal
Printable View
Friends, I have a GTI 2015 Mexican and I am from Brazil, my car when it is stopped the instantaneous consumption of it does not mark the consumption, I have seen that in some cars it is marking the instant consumption per hour. Does anyone know how to empower? type of consumption of 0.8 liters / hour
Meu amigo, sou do Brasil e tenho um Golf GTI 2015 mexicano de 220 cv que são os mesmos que vão para o Canadá e os Estados Unidos, tentei de todas as maneiras fazer a configuração através do VCDS 12.12.3 a senha é aceita 20103 Eu posso acessar os canais, mas o erro mensagem de erro na entrada, por favor, digite um byte hexadecimal, por exemplo: FF aparece e eu não posso de forma alguma fazer as alterações. Você tem alguma outra dica? É a versão do cabo?
HELP!!! My friend, I am from Brazil and I have a Golf GTI 2015 Mexican 220 hp that are the same ones that go to Canada and the United States, I tried in all ways to make the configuration through VCDS 12.12.3 the password is accepted 20103 I can access the channels , but the error message error in the input, please enter a hexadecimal byte, for example: FF appears and I can not in any way make the changes. Do you have any other tips? Is it the cable version?
hmm.............. "VCDS 12.12.3" ? Sounds like you might be using software that is well out-of-date, or it sounds suspiciously like you might be using a fake cable. If you don't have a fake cable - update the software to the latest version and if you can't (or won't) update the software, stop participating in IP theft!!
Any chance I could have a copy as well please?
I've managed to fix all but just can't get the indicators to sweep. :'(
Also my reverse lights are giving me an error too. :'(
I am not sure this issue has been closed or not for STG17 security code which need to modify instruments illumination for after MY16 model.
But friend of mine who has MY16 Golf7 found out the security code for STG17 with "47115". If not please tr.
^^^ Zeal-san: Hi
Just tried your friend's security code (47115) on STG17 on my MY18 Audi A3 (MQB platform like mk7 Golf). Alas no joy!!
