What's the voltage at the globe?
Hey Guys
I have had to change the drivers side low beam 3 times in the last 5 months and the passengers side just blew(2012 Scout 6 speed manual). It is always on cranking the engine (The bulb fail indicator will come on once engine is running).
The bulbs are Narva 55w jobs and I do use them for daylight running.
Suffice to say I dont contaminate the bulbs when handling them and the connectors dont seem to have corrosion.
Has anybody got any ideas?
I have googled this and it seems it happens to a number of skodas/audis but havent seen one solution
Nick
Are the bulbs actually failing?
If there's a high resistance in the circuit, the central electrics module won't send current to the bulb if it's outside parameters.
Check the terminals in the plug that they're providing a tight connection.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I used to blow stop and tail lights on my A4 about every 6 months. But only ever blew a single low beam once in 15+ years of VAG ownership.
As Umai said, check the resistance and voltage at the globe. If you dont have the equipment, and auto electrician can do it for you.
2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
2012 scout will be still under warranty. take it back to the dealer.
Aftermarket kit never lasts as long, but you'd think the usage rate is still a little high. Worth a check over under warranty.
could be a CECM problem. id let the dealer work it out, failing that, check out briskoda because if its happened to you, it will have happened there before![]()
I've had 2 go in 4 years in the Octavia, I'm not sure if that is unusual? We do drive a lot with them on during the day. Thank the Skoda gods the light housings are so to remove compared to other cars!
I spoke with my dealer and they have no idea as to what might be the problem. He is ordering original skoda bulbs. I think the problem is some kind of voltage fluctuation when the engine cranks. I leave the light switch to On at all times so when i turn the key the lights come on and then when the engine cranks they dim and then they get the full voltage once again. The bulbs always blow after a start up.
I have searched the froums and as I said there are instances on Briskoda of this but no answers.
I will book it in with them and get it checked but I see no point to just measuring no load voltage at the bulb socket. Could someone expand on what CECM might mean (some kind of module I figure).
For now I am getting into the habit of turning the light switch off these days.
For the record the filaments are blowing.. I think I was asked that by one of the posters here
Thanks for your help
Nick
Central Electrics Control Module.
Odd that the filaments are blowing.
'01 Beetle 2.0
