Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Replacement key Ingenious solution..or not?
    Mar 2011
    st kilda VIC
    Can i buy a used key/remote from a wrecker , get the key recut ($30)and reprogrammed at a dealer ($80) thus significantly reducing the official replacement key/fob cost? (Quoted $400).
    Will this work?!
    Dec 2008
    Sydney/Canberra
    You can't re-cut a key.
    Which bit do you need? The remote part, or the key part, or both? The remote part you can source through a wrecker, as you can reprogram them to your car, but the key, you can't.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    sydney
    you can reproggram yourself if you have an existing key.
    google it for the full run down , but from memory good key in ignition (window open) turn half on put new uncoded key in door lock , lock manually them hold something lights flash , unlock manually , bingo.
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Mar 2011
    st kilda VIC
    re-cut
    [QUOTE=Umai Naa!!;637669]You can't re-cut a key.QUOTE]
    Depending on the key type you can replace the key with a blank.
    there is a lot of info here but it is for USA cars:
    VW Key remote fob FAQ for mk4: disassembly for battery change, program instructions, and replacement cost
    Jan 2009
    blankedy
    Really? A car can program a key???
    If you just want a spare, the surf one was about 1/2 the price. No controls tho...
    Dec 2006
    Kilsyth, VIC
    I have a Mk4 Key I bought and modded to work in a Mk3. The short version is that I drilled a hole on the inside to drop my immobiliser chip (which has since been removed). The electronics still work, the immobiliser chip?? Who knows?
    I also have a number of blanks from an alterative (generic) switchblade setup that *should* fit into the key. If your interested I can drag the lot out have make sure it all fits together??
    Plan B (if my chip is dead): you can probably get your local locksmith to clone your current working key, then pull the chip out of that and stick it into my setup with an appropriately cut blank).
    Aug 2007
    Perth, Australia
    i've asked wreckers if i can buy the key, i need the whole new key and apperently a local locksmith can duplicate the blade, but wreckers wouldnt sell me only the key, they wanted me to take the whole ignition lock with the key.
    I have the v-checker and i can code the key but i need to find the "buttons" part somewhere first
    1991 BMW 318is RED E30
    Mar 2010
    Lesmurdie
    Quote Originally Posted by balkanac View Post
    Wouldn't it just be easier to buy it from like ecs at about $80?
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Mar 2011
    st kilda VIC
    Hi yeah would be interested in buying a blank and the Mk4 stuff you have. can you let me know please HAWK.
    cheers
    Seb
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Seb View Post
    cheers
    Seb
    Sending you a PM
