Urgent help! Golf gti mk4 problem!
Hi all,
My car has a massive problem, the 3rd spark plug compartment on the rocket cover area isnt giving out spark.... like say when you turn on the engine and pull out one of the spark plug leads, the car should act sluggish right? all does what i just said except one of them... The mechanic asked me if the Module or the ECU sends signal to the spark plugs. Can anyone answer that?
I already replace new spark plugs, new rocket cover gasket (due to the old one is hard and start to leak oil).
Or has anyone come across this problem before? Please Help >< car has been in the mechanic for a week already and i really need it running for uni....
The mechanic said that if its the Module, it would cost around $300 - $450 but if its the ECU, it will cost over $1000.......
Is there an alternative way to fix this problem like buy a second hand ecu or module?
Any help is appreciated guys
- You may not post replies
- You may not edit your posts
Forum Rules
