Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: MK4 clutch - options/advice...
    hi guys
    i absolutely smashed my clutch on friday night (clutch pedal stuck to the floor) so its time to start looking at replacement options
    after some advice on which option is the best for my application/budget
    although the car is standard at the moment i will eventually look into some minor mods such as ECU, intake etc so i need something which will hold up to a tad more boost than standard
    from my little research so far i only can find standard replacements which im scared i will only fry again once a reflash is done. have to remember that its is still my daily driver, so for one the car wont be driven hard very often, and two, i dont want it super heavy duty style as id learn to hate it in peak hour traffic etc
    a heads up would be great on available kits, pricing etc
    cheers, dan
    1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
    ''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
    Canberra
    First place I usually look for parts like that is ECS, with the exchange rate like it is the prices aren't bad even with shipping. The first kit on the list looks pretty good. How hard have you abused the clutch because I've been surprised at how durable the stock one actually is, considering my car is reasonably toey (though I don't do burnouts).
    http://www.ecstuning.com/stage/edpd/...ategory=Clutch
    Snowy
    Apr 2006
    VW Race HQ - Sydney
    Id say check the pedal lever first , sounds like thats snapped !
    Feb 2008
    Auckland NZ
    Bug-racer - you sure the slave cylinder did not go on the box? that will provide the same symptom.
    As for clutch replacement, you really cannot get anything better for feel comfort and driveability than the Eurospec G60/VR6 clutch kit with single piece 12.4KG flywheel. I might actually have a 9.8kg flywheel will confirm and comback on this.
    the clutch is lighter than anything i have ever driven, on the flat you do not even have to apply gas to pull away, and best off all you can go to a near standstill and still cruise along with out applying the clutch.
    But is super strong, been in my car for around 25000kms still feel the same as the day is was installed. You really cannot get anything better.
    And is rated at 450hp.
    Sweet.
    Hope this helps as for a clutch kit combo for a mk4 gti.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Apr 2006
    VW Race HQ - Sydney
    They generally leak fluid as well , he hasnt mentioned oil stains on the ground
    Quote Originally Posted by glidn View Post
    Camden, Sydney
    I would change it for a conventinal flywheel and vr6 clutch too. Get away from the dual mass nonsense.
    Don't go buying a clutch before you diagnose it properly. This is far more likely to be a pedal or hydraulics issue than the clutch itself.
    I have a slave cylinder which is brand new in my shed, if that has gone
    The pedals seem to break pretty often too like Seb says.
    Aug 2007
    Clutch Master cylinders are bad too ( fluid on the floor) And yeah gotta agree with the pedal snap situation. If the Big spring/ring that is part of the pressure plate snaps this too can happen seen it many times but another sympton with this is no drive as you lose spring pressure. So although you have a pedal on the floor you should be able to start up in gear and take off , this will tell you the clamping force of the pressure plate is good and the clutch plate is good.
    Jmac
    Alba European
    Sweet.
    what sort of price are we talking for a clutch kit such as this?
    Jump on ECS tuning website. Go through as if you are purchasing it and it will give you a shipping quote also
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
