Ah dammit, got my ecu's back from C2 and appears they've programmed my spare with the turbo file but done the immo defeat to my original ecu instead of my spare ecu :/
Dammit... waiting to hear back from c2 now to see what they say.
Have they done a file for the same setup before?
VWWC Members - 2018 Special - ECU & DSG Remaps
DNA Tuning Australia - Enquiries: info@dnatuning.com.au
I believe so. The reason i believe they've put the immo defeat on my original ecu is because they've written on the ECU's what they've done to them.
My standard one has written on it "12-01-10 stock ecu" and "12-01-10 C2 Immo Defeat"
My spare one to be used for the turbo software has "12-01-10 C2 stg3 24v 630cc 4"maf"
Thus i am thinking they thought the ecu i wanted re-flashed with the tune was my original ecu thus they didnt need to immo defeat it and that what is actually my original ecu was just a spare that i bought and thus needed the immo defeat done on that instead.
If thats whats happened i'm a bit disappointed because i clearly marked on my standard ecu "Original ecu please dont modify / re-code" and clearly marked my spare ecu as "ecu for re-flash"![]()
have you tried the ECU yet. Chris is pretty straight fwd!
SLAM.POKE.TUCK.DROP.DOPE!
I havent been able to since the cars in many pieces! Oh well on the up side if the ECU does need to go back to C2 i guess i can take the opportunity to get the SAI and Cat deleted from the software!
Edit:
Chilled out a bit now, Called C2 today and although i couldnt speak to chris as he's out of the office till next week the guy i spoke to thought that both ecu's had the immo defeat performed on them. I'm still confused as to why they would've immo defeated my standard ecu but oh well as long as the second one has been done that all that matters. Still, i'm looking forward to chris's reply to my e-mail to confirm this but things are looking up again.
Hopefully the SRI intake and head spacer arent too far off so i can get things cracking on
If it wasn't 41 degrees today i'd pull the gearbox off and get that done... oh well, more procrastinating!
Time for an update?
Well i got down and dirty a couple nights ago with the bora and off came the gearbox!
Followed this guide VWVortex.com - Transmission Removal Clutch Replacement diy Quick Version and its pretty much spot on. Note that when seperating the transfer case and gearbox you can expect a flood of transmission oil to spill out. I'd recommend draining the box before doing this to save getting covered in oil... doesnt taste great
Two of the trickiest bits was manouvering the gearbox off after unbolting it and also getting the 6mm allen bolt from out of the transfer case, although not hugely tricky just frustrating (the one buried deep in the drivers side driveshaft, step 21 in the vortex guide) Initially i bought several allen key extension shafts however i broke all 4 that i bought!!! In the end i ended up making my own by welding a 6mm hex head with a drive adapter to the threaded rod from a spring compressor... Believe me, this one will NEVER break!
For removing the gearbox personally i would recommend using an engine hoist to support the engine or having an engine support brace like seen here http://www.lonestarminiclub.com/gall...0/DSCN0648.JPG
It's not completely necessary, the Vortex guide uses a jack to support the engine, however in honesty its not hugely stable like that and could easily slip out of the drivers side mount, especially when your rocking the gearbox / engine assembly to get the bastard out. So between an engine to the face or 5 minutes rigging up my engine crane, i decided on the safer option!
Upon getting the box off i was pretty happy to see the clutch seems quite new. Even though its going to be replaced it means that the rear main seal didnt just look new, it probably is. I'm not a fan of replacing rear mains when they're not leaking as sometimes they then leak! Luckily this means somebody else has risked changing it and won. The dual mass flywheel also looks to be in good nick, not rattly and smooth. Again this is also going though as i have a lightened chromoly flywheel and carbon ceramic clutch to go on
For getting the box back on i'm actually almost contemplating dropping the motor, there really doesnt look like theres much left attached to it other than some cooling lines and a couple wiring looms and being rigged to the engine crane means it might only take an extra 10-20 min vs wrestling a gearbox for the better part of 30m-1hr! Hrmmm decisions decisions.
Next steps from here is to order in the seals for the trans - transfer case, pull the sump to weld in a oil return, put the new clutch on and after that just paitiently wait for my intake, head spacer and a few other bits from C2. Might give them a call monday their time to assess where they're at. Once i've got the final bits from them i'll hopefully have it all running within 2 weeks
I'll update this with pics shortly when i get home from work
Pics:
The damnn 6mm hex buried in one of the shafts
The broken extensions
The solution
Safety first!
Happy days
2 weeks? you're the friggin' man, i love this build. but we do NEED pics. I can't wait to see this.
Would you be ok with a visit one day when she is running? I'd love to swing by and take a look, cause i've been trying to get the missus and baby down to the Barossa anyway for a weekend so might fit well.
MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
