Results 1 to 10 of 18
Thread: T5.2 (2011+) OEM retrofits: RNS510 nav, 9W7 bluetooth, RVC, MFSW
Threaded View
YellowLemon T5.2 (2011+) OEM retrofits:... 13-04-2015, 12:29 PM
Sunny43.5 I can help with two items ,... 13-04-2015, 04:37 PM
YellowLemon Thank you for the info! :cool: 13-04-2015, 05:04 PM
Guest My bluetooth black box is... 13-04-2015, 09:51 PM
YellowLemon RNS510 DAB+ has arrived from... 17-04-2015, 03:17 PM
Sharkie Out of interest, where did... 17-04-2015, 04:01 PM
YellowLemon Carsystems have them complete... 17-04-2015, 04:28 PM
YellowLemon Rear view camera 22-04-2015, 02:24 PM
YellowLemon 9W7 Bluetooth 22-04-2015, 02:31 PM
YellowLemon MFSW steering wheel with DSG... 22-04-2015, 02:40 PM
YellowLemon Other small upgrades 22-04-2015, 02:41 PM
Sunny43.5 Great write up and photos I... 22-04-2015, 06:08 PM
YellowLemon Ah yea those are wise words.... 22-04-2015, 06:28 PM
nicmic72 Hi guys, great write up of... 05-06-2015, 10:44 AM
YellowLemon 2011 MY bluetooth works fine... 05-06-2015, 01:12 PM
nicmic72 [QUOTE=YellowLemon;1134437]201... 05-06-2015, 01:36 PM
YellowLemon Actually the bluetooth module... 05-06-2015, 03:01 PM
Sunny43.5 For YellowLemon I just read... 05-06-2015, 02:22 PM
    Mar 2011
    Gold Coast QLD
    Thumbs up T5.2 (2011+) OEM retrofits: RNS510 nav, 9W7 bluetooth, RVC, MFSW
    See below in this thread for information on these additions to my T5.2 Comfortline Multivan:
    • RNS510 navigation radio
    • 9W7 bluetooth kit and microphone mounting
    • RVC rear view camera
    • Steering wheel with DSG paddles, multifunction buttons, and flat bottom from mk6 Golf R
    • Extra 12V sockets on top of the centre trim (like in the new MY2015 T5.2) and in the glovebox (constant on)
    • Add light to glovebox. VW DIDN'T PUT A LIGHT IN THERE?!? What a joke.
    • LED bright number plate lights (from R-dash)
    • Rear fog lights rewired as backup brake lights (2x diodes on each tail light assembly)
    I've started separate threads for these mods:
    Still to do:
    RNS510
    Great info in the forum sticky: T5.2 OEM Radio Options - fitted post delivery
    To get to the 4 screws holding the RNS510, first unclip the trim at the TOP of the centre dash, by pulling vertically up, and this reveals two torx screws holding on the front fascia of the centre portion of the dash.
    9W7 BLUETOOTH MODULE
    1. The stock location for the bluetooth black box in the T5.2 Transporter/Multivan is under the driver seat. (thanks IN2VWS) However carsystems.pl support says they prefer installing it behind the dash, saying there is plenty of room.
      Links:
      MY11 Multivan Bluetooth - can it be fitted later?
      Help !!! Fitting an aftermarket bluetooth to my 2013 Multivan
    2. The A-pillar is held on with clips but you have to remove the unscrew the grab handle first (after removing the handle cover).
    3. The microphone usually has a separate bracket in the T5, part number 7H5 857 155. Although the centre overhead light console also has a spot for the microphone - see posts below for how to fit.
    RVC REAR VIEW CAMERA
    Best path for the wiring: Up in the roof liner and then down the A-pillar sounds easier than along the floor on the sides (which needs unclipping of the sliding door steps/sills, what a pain!). See post below for update on the RVC install!
    GOLF mk6 R - FLAT BOTTOM MFSW MULTIFUNCTION STEERING WHEEL
    Since this Multivan has no buttons whatsoever, I will need to run two wires to the steering wheel slip-ring/clockspring: one for 12V power and one to the BCM for LIN-bus connection to the little module inside the steering wheel. See post below for instructions.
    Last edited by YellowLemon; 01-11-2015 at 11:32 PM. Reason: Updates on work completed.
    - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
    - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
