Results 1 to 10 of 11
Thread: Thermo fan NOT WORKING
    Thumbs down Thermo fan NOT WORKING
    my thermo fans not working and im at a loss as to why, because it worked just fine before i did the engine swap.
    any ideas? i've checked out 2 fans, bipassed the radiator switch to hard wire it and both dont work, maybe a fuse?
    cheers
    Jun 2006
    Orange NSW
    Yeah grab a meter and make sure you've got power dude.
    Apr 2006
    Hobart,Tas
    They are the most simply wired thing on the mk1s.
    Power to fan and negative switching through the thermo switch!!
    Andrew
    will do mate
    Quote Originally Posted by gtimk5 View Post
    Andrew
    ARGGHH i hate wiring mate
    Oakleigh VIC
    If there's no power check your fuses, mine was wired to the one on the far right.
    Pete
    cheers ill check it out, hopefully its just a fuse
    May 2006
    Maryborough Vic
    Talking
    if its not a fuse, check your plugs in the back the fuses
    that was the cause of mine not working
    cheers chaps, will do tommorow in the light
    Aug 2005
    Quote Originally Posted by GoLfMan View Post
    Doing an engine swap is more than enough of a reason to stop things working!!!
    I'm sure there's just no power at the connector, as others have said. Pull a supply voltage straight off the battery and see what happens
