Results 1 to 7 of 7
Thread: Lap Belt 90 Cabrio
    Jun 2009
    Manly Qld
    Lap Belt 90 Cabrio
    Hi,
    These lap belts in the Mk I Cab, are they suitable for fixing a baby seat?
    It's not a fixed over the shoulder seat belt, just the pull out lap belt. Does anyone know the right (legal and for best safety) way to do it?
    Thanks
    Oct 2005
    SE Queensland Hinterland
    Pretty sure they are not, but try this link
    https://www.tams.act.gov.au/__data/a...iving_2009.pdf
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Apr 2009
    Newport, NSW.
    Wouldnt say theyd be the best things to fit a baby seat...
    Maybe use the lap belt at the bottom and find a harness point in the boot to hold the top of the baby seat.
    Camden, Sydney
    A capsule, or a seat with a rigid base should be fine with an upper mounting point on the bar behind the seat.
    Small kids fit in the tiny rear seat pretty well with just the seatbelt. No good for babys tho.
    Jun 2009
    Manly Qld
    Matt,
    An upper mounting point? Do you mean an anchor point (I assume there would be 2 in the Mk I 90 Cabrio) or do you mean putting something extra in to keep it fixed?
    Matt
    Dec 2007
    Somewhere in Melbourne, Victoria
    Anchor points should be located on the cross member running behind the back seat between the wheel arches.
    The lap belt should thread through the base of the seat, pull it all the way out, keep it fully extended until the lap belt clasp and buckle are fastened. Once you do this the belt should ratchet, thereby locking the belt to the correct size and tension.
    The anchor point harness should slide through a small slot in the parcel tray behind the seat and affixed to anchor points on the cross member.
    A word of warning though, when installing the roof should be down so you can access the back of the baby seat easier and feed the harness behind the seat. One trap is if it is a toddler seat and has a high back, this may catch the roof when it is put up or down.
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Jun 2009
    Manly Qld
    Quote Originally Posted by paulie71 View Post
    Cheers Paulie, very useful.
