Results 11 to 20 of 22
Thread: The KillaWasp
    Sep 2009
    Chillaxing in Tas
    I would if i was staying in tassy
    And its far from prime, pic makes it look mint haha. paint is bad as, but its a no thrills daily.
    <space for rent>
    Jun 2007
    Eastern Suburbs Melbourne
    nice pick up mate, looks pretty tidy indeed!
    although, you do have the disease! ahah
    i like volkswagens
    Sep 2009
    Chillaxing in Tas
    its my 3rd Mk1 in 9 months i think
    green one which i still got
    Blue one which body was rooted, but had heaps of good parts
    now the yellow one
    When will it end? lmao
    <space for rent>
    Nov 2009
    Hobart, Tasmania
    Nice pickup. I actually remember seeing this one for sale a few months back when I was first on the lookout for one. I called up and the owner had just sold it. Maybe the new owner might not have realised that Mk1s are playful, and don't always work the way you would like.
    Sep 2009
    Chillaxing in Tas
    Ahhh busy day so far!!
    Done a heap of wiring fixing, got some things working, and others not.. but going to buy new wire to redo some earth points as i know they play a big part.
    Put parcelshelf and holders in, speakers in, sterio in, degreased engine and box and the whole bay.
    Neatened up bay a bit, put my badgeless grill on.
    Put sealant on tappet cover to fix leak, will do till i get a new gasket.
    Things to do so far,
    Radiator leaks... pretty bad actually.
    exhaust rattles
    timing cover clangs one engine when idle.
    Going to swap my 15's onto it
    GTi flares
    Unsure about the 2 piece duckbill yet
    Wash it
    Pics to come, tis hot and i need a break haha
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    So i fitted a Later model Radiator with the External fill up tank thingy
    Thing is the fan doesnt kick in and the water starts to flow out of the tank. (lid was off to get out air bubbles.)
    The fan works, and so does the sensor as it worked 2 days ago in my other golf. Whats next point of call? i checked all fuses, checked earth wire.. no sure what to look for now.
    EDIT, seems i has a wire missing from the G section on fuse panel, its G6 which going by the diagram i found is a radiator thermo switch. i have nothing there. but the wire is near radiator.
    I cant see any unplugged plugs, so im guessing its been cut or something? not sure.. might run a wire from G6 to switch and see if it kicks in
    <space for rent>
    Sep 2009
    Chillaxing in Tas
    SO progress on this one slow atm
    Waiting on a new radiator to show up, wired in a Craig Davies Thermatic switch ready for the fan.
    Carpet dash out of my Green one is in. was a good time to neaten wires and try fix a few problems. think i got most
    Front lip on, Black strips off bumpers as bumpers need a polish, and the strips need painting.
    15x7's all round, Got some thick swaybars to chuck on when i can be bothered to pick up the rest of the mounts.
    Waiting on a Tappet gasket, manifold bolts, and head studs to hold tappet cover on.
    Few pics, She may be up for sale soon so keep eye out
    <space for rent>
    Jan 2010
    Melb Westsideeeee
    Nice work mate, got alot of problems that you can happily tick of as -done-.
    I think you should leave that big duckbill, looks good imo. Coming together slowly, but nice at the same time. Not much left to get it going is there, apart from the bolts and gasket?
    Sep 2009
    Chillaxing in Tas
    Radiator put in
    Carby back on manifold and manifold back on when bolts get here
    Tappet gasket and studs
    Fix oil leak around dipstick
    Tidy inside and fix most of the electricall problems that i can.
    Then sell
    <space for rent>
    Jul 2009
    Ringwood,Victoria
    My indicators were working intermittently as well , found it to be loose terminals where the negative wire meets the body connection , just behind the headlights.
    Hope this helps.
    "That's what she said"
