Results 1 to 9 of 9
Thread: Indicator blinker frequency, how is your Mk1 ?
    My Mk1 left and right blinker frequency was different, right one is faster like (da.da.da.da.da.) compare to left one which is similar to Mk4 (da....da....da....da....) not sure if this explains clear enough
    Last week I replaced the blinker relay, I expected both side be back to da....da....da....da.... pattern, but it turned out the other way. Both side now is da.da.da.da.da..
    Is this normal ??
    Feb 2006
    Perth Western Australia
    dude if the flasher is travelling at twice speed it is almost definitely a blown indicator bulb, chuck the hazards on and do a walk around, you will most likely find you have bulbs out
    luke
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Jul 2006
    My indicators are weird, sometimes they go fast and sometimes normal
    Perth. WA
    Also check that the globe holders are earthing correctly...
    Mine tick at different rates, left is steady rate, right changes as it sees fit..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    if its bulb or earth problem, why changing a relay make a difference ??
    Apr 2006
    Hobart,Tas
    Check your globe wattage. 18 or 21 watts are the size, marked on the globe itself.
    I am thinking you are going to hit me with some questions tomorrow when you see me....
    Andrew
    Quote Originally Posted by gtimk5 View Post
    Andrew
    I'm going to ask you to pull out the gearbox for me Andrew Have a nice trip
    Jun 2008
    Hobart, TAS
    hey mate,
    i've just finished fixing this problem with mine.
    turned out it was a combination of dodgy elec supply to indicator and the grounding terminal was also dirty, therefore having intermitent working indicator. I'd also check the globes and try a few different things here and there, old golfs are known for their character haha!
    cheers
    Jan 2008
    Canning Vale, Perth, WA
    bit off topic, but the ADR regs require a flasher to operate 60 - 80 times a minute. if youre outside that range and cop can put your car off the road (but probably only if youre not nice to him LOL)
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
