Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 70
Thread: VAG-COM Logging
  1. #41
    Jan 2009
    blankedy
    409 for mine, if your using the USB type, Think you need the next one up.
    Have you connected to your car? Can you scan codes? If not, you still may need to be working on the drivers...
  2. #42
    Sep 2006
    I have scaned it and cleared all the codes
    Still trying to work out the logging
    Some of the things look different on the screen on the version i am using
    I am using the 908
  3. #43
    Sep 2006
    Ch 115 only gave me this
    09:55:09 Group 115
    720 /min RPM
    20.3 % Load
    1010.0 mbar Absolute Pres.
    09:55:09 Group 115
    760 /min RPM
    20.3 % Load
  4. #44
    Jan 2009
    blankedy
    yeah... thats what you want... then you need to log it as you drive...
    This records the same info, but over time, then you can graph it!
  5. #45
    Jan 2009
    Bucharest, Romania
    I've installed the FORGE TIP and made some more logging:
    so here's boost before and after the tip
    BLUE - before the TIP
    ORANGE - after the TIP
    So, with the TIP only the requested boost seems to be higher all over the rev range
  6. #46
    Jan 2009
    Bucharest, Romania
    And here's an AFR graph in 2nd gear:
    (made with the afr example from ross-tech page - Ross-Tech: VAG-COM: Diagnostic Procedures)
    And a graph with air mass / inj period / load made with the same values used in the afr graph:
    How does this look ?
  7. #47
    Sep 2006
    Did a log again in 2nd gear all it gives me is this
    Shouldnt it give me more info, it should be recording
    Can anyone show me what the data should look like after taking a boost log of a certain gear
    Address 01: Engine (06A 906 032 TL)
    09:48:32 Group 115
    760 /min RPM
    18.8 % Load
  8. #48
    Point Cook, Vic
    your data should be in the form of a .csv file.
    That looks like just a snapshot at idle
    FOLLOW US ON FACEBOOK
  9. #49
    Jan 2009
    blankedy
    does not seem like you are logging, just looking at data...
    You should be exporting a file (.csv).
    You need to go into Meas. Blocks, select your blocks so you can see the data live, select log, it will open up a little window for the file location, give it a file name (pref on the desktop), select Start. Do your runs, then select Stop. This is based on the 409 Software, but should be pretty similar.
    What you get is a spreadsheet with lines of data which are time seperated, then you can make a chart with this info.
  10. #50
    Sep 2006
    Thanks guys found some logs in some of the files
    Info looks messy, not consistant
    Trying to work out how to graph it as I havent used excel before
    Data looks all over the place as i did it is 2nd gear
    Might need to get a good log in 3rd
