Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Self Maintanance Tips 101
    Jun 2007
    Quote Originally Posted by Bumpknuck View Post
    noticed air pressure in tyres was off today....fill em up when cold or after a drive?
    cold cold cold
    Feb 2008
    Perth, WA
    i go 2 psi over what the factory recommendation is...i was 5 over today (hot as hell in Perth tho and driven pretty hard) - im thinking thats too much over the recomendation?
    Jan 2008
    Canning Vale, Perth, WA
    I run mine at 38psi - harder gives more wall stiffness and better handling. also means longer tread life (just dont overdo it or you bulge the tread and get a wear strip down the middle).
    also, recommend you get your own little tyre guage - the ones at garages are notoriously inaccurate
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Jun 2008
    Quote Originally Posted by Adam View Post
    cold cold cold
    never ever deflate a hot tyre!
    You can inflate the tyres after driving, but it wont be accurate and from what i read, i think you need to put 8-10psi more than what you normally would put when the tyres are cold.
    Mar 2007
    VIC
    Quote Originally Posted by Spec83 View Post
    Have them machined or I believe there is some form of anti-squeel spray you can get from auto shops
    Does that just blast the stones out of the brakes?
    Nov 2008
    Quote Originally Posted by poloplayer View Post
    From my use of anti-squeal on motorbikes you apply it to the back of the pad. NOT to the discs. It works between the pad/caliper interface and stops the noise there rather than the pad/disc interface.
    Essendon
    Always cold... but sometimes it's not always convenient. What I do if I suspect my tyres are off is just before I've done all my driving for the day, I'll put in 45psi all round at the closest petrol station near home. The next morning, I'll go out with my tyre gauge and deflate them to whatever I want them at.
    Sunroof // ICT Tint // Seats // Steering wheel
    Dec 2008
    Perth
    Decent bicycle pumps have gauges on them, although they are fairly hard to read. But they're only ~$50 and very handy!
    Quote Originally Posted by DeanB View Post
    The squeal is caused by a build up of brake dust on the pads. Hit them with the garden hose, much cheaper than anti-squeal.
    Paul
