Results 1 to 10 of 16
Thread: Next mod: TIP?
    Jun 2012
    Canberra
    Next mod: TIP?
    hi all,
    Currently I've got PD160, K&N panel filter and APR stage 1 tune (and lemmiwinks 6 degrees ignition timing advance). The car pulls pretty well from 2,500RPM to about 5,000RPM, then it runs out of puff, just wondering if it will be worthwhile to get a TIP? How much gain should I expect?
    Found this on ebay, it seems pretty cheap:
    VW Polo 1.8T and Ibiza FR MK4 TURBO Induction Intake Pipe SILICONE HOSE | eBay
    Is it possible to install it myself?
    Thanks!!
    Melbourne, Vic
    I have similar mods to yourself and was thinking of doing it, from what I read its a total pain in the ass to install and the change noticed is a more linear power curve.
    Some people wished they didn't do it.. Anyone whose done it care to comment?
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
    May 2011
    Albury, NSW
    In my opinion and a few other people would probably agree that you'd be best going for FMIC next, then a 2.5" DP and then the TIP - I have the forge TIP - absolute bitch to install - I didn't believe everyone when they said it, but it was a nightmare, that ebay link looks very similar, if it definitely fits then it's a very good price. Just give yourself a lot of time to do it and read everyone's install instructions to get some tips - no pun intended. If you're looking for gains then you need to ditch the stock intercooler - because that running out of puff is probably more heatsoak from the turbo spinning so fast.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Nov 2007
    I would recommend the TIP to everybody. I have 1 and have no issues right up to the rev-limiter cut-out ..... whilst a PITA to fit its definitely worth it from a performance perspective.
    Feb 2007
    Brisvegas
    Agree with Sharkie here.
    Flow is restricted with the OEM TIP and it collapses on a tuned car at WOT robbing you of power. Going a Forge TIP will increase flow "slightly" but will not collapse which is what Sharkie is referring to when he says the power band will continue in the higher RPM range with an upgraded TIP. Latest dyno comparisons made by Bill at Badger 5 in the UK show a 20hp atw gain by going to an even larger ID TIP on an ko3s hybrid turbo setup. 80mm all the way through iirc.
    And I have felt the ebay jobs and they are a lot softer than the Forge TIP so don't be surprised if they also have a tendency to collapse.
    Mine goes ok on rubber TIPs.
    I have always had silicon ones until now though. I will be getting that ebay one next week, to modify it and fit to the Frankenturbo.
    At the end of the day don't forget that the K03s isn't that big a turbo.
    I'd probably go with a downpipe before intercooler but it depends on your ultimate budget, things get out of hand just read my thread about that.........
    Jan 2009
    Quote Originally Posted by bakersdelight View Post
    hi all,
    Thanks!!
    Mine with similar mods and the TIP pulled quite nicely to say 5700/5800, though beyond that it was running out of breath pretty quickly. As already suggested, that feeling is likely to be heatsoak oriented and some boost drop. With SeatSport FMIC, it's smoother, doesn't drop off as quickly, though I rarely rev it out on the street, and track I usually shift 6-6200 as I've found that to be optimal. I am referring to 3rd and 4th gear, 2nd will run to red line without a noticable drop.
    Can yet comment on the dump pipe as I haven't done it. Though my opinion is that I'd still do it in the same order as I have.
    Daily: 2010 VW Jetta Highline
    Feb 2007
    Brisvegas
    Gav yours is positively FFFFFing mental. It's not even tuned yet and it's off chops with the franken on. Peaking at 26psi I wouldn't be surprised if you suck the rubber part of the OEM tip through the turbo
    Feb 2007
    Brisvegas
    And don't get me wrong I think the TIP should be upgraded along with the intercooler and DP but you won't get the full potential with a OEM TIP. Check this out
    Just look at the restriction down the bottom near the turbo inlet and the overall difference in volume.
    Dec 2012
    hi all,
    Thanks!!
    Ever thought of installing a forge DV? Might hold boost a little better? Very easy to install as well, unlike the TIP, $68 soon becomes $680 after you give up and pay someone to install it lol.
    Also does you EPC light "confirm" your selection when you change program's on APR? It's supposed too but mine doesn't.
