Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: How to reduce acceleration in a 118TSI
    Apr 2011
    Caves Beach NSW
    Hi, My wife will not drive our 118tsi because it accelerates too quickly from a standing start. She does not have control of the acceleration peddle for a slow even start. She currently drives a 1.4 Kia Rio which I would like to get rid of and only have one car.
    Is there anything that can be done to reduce the initial acceleration. We have had the VW for 3 years and she has only driven a couple of times.
    The Point is that we only need one car.
    I hope some one can help.
    Correct seating position will ensure that she has good control over the throttle.
    Dec 2008
    Sydney/Canberra
    You can't just mash the accelerator and take off, like you can in a conventional automatic.
    You use the accelerator in much the same fashion as you would in a manual car, i.e. feed in a small amount of throttle, wait for the clutches to take up, then feed as much throttle as needed to get up to the required speed. The DSG is, by design, a manual transmission, that shifts automatically.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2012
    Sutherland Shire, Sydney
    Driver education and practice would be the best option
    Failing that you could look for one of those electronic throttle control devices that promise to transform your car
    They really are snake oil, they are just modifying the throttle settings sent to the ECU
    But these devices often provide multiple throttle mappings
    A mapping where much less throttle is sent to the ECU at lower throttle positions would help your wife
    Nov 2007
    Perth
    The MK5 GT TSI had a winter mode button that would start you off in second gear, dulling the acceleration quite a lot.
    Is there anything like that down near your shifter?
    Dec 2009
    Sydney NSW
    Quote Originally Posted by Umai Naa!! View Post
    why not ? it what I have always done in DSG Golfs i have driven, if you want to take off slower, just lightly press the accelerator.
    mk VI GTI, manual, reflex silver, basic
    Dec 2008
    Sydney/Canberra
    It's the same as dialling up a bucket-load of revs and stepping off the clutch.
    '01 Beetle 2.0
    Dec 2012
    Quote Originally Posted by mfl View Post
    Yes - we all know that - we are talking about a wife who has little interest and affinity with cars
    I know ladies that either can't shut the door or slam it - nothing in between
    I can only assume the OP's wife has driven automatics with torque converters for many years and this has taught her to hit the throttle hard
    It's also a credit to a basic car that it feels so zippy - the VW TSI/DSG is very practical and effective
    Sep 2014
    Christchurch NZ (ex Brisbane)
    Quote Originally Posted by Martin View Post
    This^^^ not trying to be rude but driving properly is an art (much like being good at anything it requires the practicing the correct methods correctly to perfect it).
    Used to do so much driver training where people just would not sit properly or just mash the throttle...
    Dec 2009
    Sydney NSW
    My point is that there is no difference driving a torque-convertor auto and a DSG at a basic level.
    I understand what the OP was referring to, but you wouldn't get into a 6 cylinder or 8 cylinder auto either and just hit the throttle hard.
    If you get something like the 'sprint- booster' to work in reverse that's one solution.
