Page 45 of 120 FirstFirst ... 3543444546475595 ... LastLast
Results 441 to 450 of 1199
Thread: DSG: Problems, Questions, Likes and Dislikes
  1. #441
    Feb 2009
    Sydney, Australia
    Well REXman, I haven't experienced it, and I was directly replying to another member who believes he's experienced it but was also questioning whether it was clutch slip or ESP... so no blinkers involved really, just questions...
    In any case, if it is clutch slip, should be pretty easy to identify via logging with VCDS.
  2. #442
    Mar 2010
    I have noticed, especially when its cold, that the DSG makes a few loudish "clunking" sound when I go from R to D. Its a very noisy engagement.
    Even when warmed up, still makes the same noises, although not as loud, but still audible when going into 1st gear.
    Service centre said that it was a normal sound, and nothing to be concerned about .............. just like the rattle ........
    MK VI GTI / 5 DOOR / DSG / LEATHER / TORNADO RED / APR STAGE 1 / CARBONIO CAI STAGE 1 + 2 / VMR VB3 18" MATTE BLACK
  3. #443
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by nat225 View Post
    I may have had a clutch slip in my mk6 118TSI or perhaps a 7speed DSG problem, it happened a couple of times and each was during sharp cornering and accelerating at the same time. I heard banging noise and sounded like the gear couldn't get engaged or something. When I released the accelerator then push it again gently then it went ok.
    Have no issues or whatsoever with my Mk6 GTI DSG gearbox
    That sounds more like ESP. It will reduce the power and if there is still a problem, engage individual brakes. Having provoked a Honda into engaging the ESP, that's just what happened.
    but just because it sounds like ESP doesn't mean it was in your case.
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
  4. #444
    Nov 2009
    Quote Originally Posted by Corey_R View Post
    If you can suggest what fields to monitor, I'll happily go out this weekend and try to repeat it!
  5. #445
    Feb 2009
    Sydney, Australia
    The best person to ask would be logger. He has done logging on the 7sp DSG box several times and provided answers to us here about what it's doing when moving from take-off and shifting etc. I just can't remember which thread it was in to find the details....
  6. #446
    Mar 2010
    Witness Protection
    Quote Originally Posted by weewilly View Post
    I'd be using the 'WAX' as lube on their collective ***holes. what game are they playing??
    Well said.
    Could you please name the dealer who is fobbing you off?
  7. #447
    Nov 2009
    Never thought I'd read that LOL
    edit:
    Is this what you were talking about? http://www.vwwatercooled.org.au/f112...tml#post551846 (Post #29)
  8. #448
    Feb 2009
    Sydney, Australia
    Yeah that's one of the posts! Does the spreadsheet give you any idea about what you'd need to monitor in the DSG?
  9. #449
    Nov 2009
    Could take a stab using the clutch path/position along with accelerator position, speed, rpm and gear selected along with some temps. I think you can get 12 fields at a time. If you look in the Labels dir where you installed VCDS, open file "02E-300-0xx.lbl" in a text editor and that will show you all possible fields to log. The 2 clutch path fields logger used aren't available so not sure what to select there.
    Though from memory I think every time I tried to do advanced measuring on my DSG the VCDS application would crash. I had to use the normal measuring blocks screen and select the predefined groups when I did the temp logging. Never tried another laptop to see if that was the issue or not, nor follow it up with Ross-Tech.
  10. #450
    May 2010
    Well, unfortunately, it did the slippage again.. twice!! Once in the city, once on the way home.
    Nearly all the times so far.. it does it in slow speeds, usually when it is going to\from 2nd gear. And then it just slams the redline. 1st time tonight in the city was a bit iffy but lucky it was only around 11am so not many cars around.
    So its now at the stage though.. where I have to get it checked.
    I have done 3400kms.
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
