Yeah I was more concerned as you mention, about longer corners where you want to hold revs.. so manual mode is fine. Thats good to know !!
PS not bad for a stage one there
Should be quicker than the 5.7 they quote to a 100. And if you bothered doing the intercooler, Down pipe and Air intake.. should be alright.
This will be a car I dont replace the whole exhaust on (as I normally do). Apparently, If you isolate the part of the exhaust which is bottlenecking the flow, you might find you only need to change the DP, for instance.
I know on the XR6 Turbo for instance, the whole exhaust has been proven to be great and only needed the rear muffler changed for bang/buck. Apparently the rest of the exhaust flow well. Ill have to do soome research on the golf situation.
I cant be bothered upping the turbo on this one.. So ill probably just do the above (cooler, air, tune, DP).. which I am not sure what that would net.. but would be alright.
I'd love to know what a nicely worn in motor with 10-15000KMs on it makes..
2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
