Results 1 to 10 of 11
Thread: ABS causing many issues, cannot fix so far
    Sep 2024
    Brisbane qld
    Hello everyone, this is my first proper post outside of the Newbie section. Im mostly certain that this type of issue hasn't been discussed on this page before but I apologise if it has been. So I have a 2011 mk6 golf 103TDI, and its got an issue. It started probably a year ago ish and has slowly worsened, I am having an issue with my abs which triggers an engine fault, then the power steering, speedo, and then the fuel gauge to bounce/ move around.
    To get into the details of the issues,
    • the traction control, abs, and stability control lights come on as well as the hand brake light flashing, on the dash screen it says brakes error workshop
    • the glow plug light also flashes as well as the engine light on too
    • most of the time the steering light is on as well, indicating the power steering is out, this sometimes does go out but is getting more and more rare
    • additionally and this is the part I find most odd, the fuel gauge moves, eg. when I put my foot down, or am on a hill the gauge is in the incorrect spot and bounces around
    It initially started with the abs lights coming on rarely, and I'd power cycle the car and they would go. This progressed to them being on constantly but only going away once the engine was at temp. then power cycled, this solution did however slowly stop working and it is now at its current point as described above.
    what I've replaced,
    • all four abs sensors ( though cheap eBay ones I wanted to prove that they were not the fault, which is has been confirmed that they are not)
    • all abs, and stability control related fuses and relay
    • the multi/ central fuse on the side of the fuse box ( replaced today, did a test drive and the speedo came back only after power cycling, all other issues remain)
    • battery has been tested, grounds have been checked and abs module connections have been cleaned
    With all these issues the car still drives fine, though I have to use Waze for speed but everything else works great, engine/ dsg.
    I really appreciate any help or advice anyone has, this has slowly become an annoying and expensive issue. I really don't want my first car to die after only 2 yrs of owning it. I'm dreading that it is the module itself but I know that's the most likely cause. ( happy to post error codes and photos if thats any help)
    What are the fault codes?
    Those generation of MK60EC1 ABS modules are prone to controller failures.
    Sep 2024
    Brisbane qld
    I replaced the mutli fuse (1k0937629a) based on 00668 code for term. 30 but that code still shows unfortunately
    Thanks.
    Car Scanner ELM OBD2
    DTC report
    Selected brand: Volkswagen
    ============1==============
    U0415
    Raw code: C415
    ECU: Engine control unit
    Status: Pending
    Invalid data received - anti-lock brake system (ABS) control module
    ============2==============
    01303
    Raw code: 0517
    ECU: 19. CAN Gateway
    Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
    Phone Transceiver-R36; Transmitter and receiver for telephone R36
    ============3==============
    02395
    Raw code: 095B
    ECU: 09. Onboard supply control unit
    Status: Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory
    Front Right Parking Lamp-M3; Front right parking light bulb-M3
    ============4==============
    18255
    Raw code: 474F
    ECU: 02. Transmission control unit
    Status: Validated and stored in non volatile memory, Validated fault present at time of request
    P1847 Read data from the fault memory of the ABS control unit; Please read out the fault memory of the ABS control unit
    ============5==============
    16352
    Raw code: 3FE0
    ECU: 03. ABS control unit
    Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
    Control block; Control unit
    ============6==============
    00668
    Raw code: 029C
    Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory, Validated fault present at time of request
    Vehicle voltage, terminal 30; On-board voltage terminal 30
    ============7==============
    00287
    Raw code: 011F
    Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
    Rear Right Wheel Speed ​​Sensor-G44; Rear right speed sensor-G44
    ============8==============
    00290
    Raw code: 0122
    Rear Left Wheel Speed ​​Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small
    ============9==============
    00285
    Raw code: 011D
    Front Right Wheel Speed ​​Sensor-G45; Front right speed sensor-G45
    ============10==============
    00283
    Raw code: 011B
    Front Left Wheel Speed ​​Sensor-G47; Front left speed sensor-G47
    ============11==============
    04278
    Raw code: 0010B6
    ECU: 01. Engine control unit
    Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear, Warning indicator requested
    U041500: Invalid Data Received From, Anti-Lock Brake System Control Module
    ============12==============
    13701904
    Raw code: D11310
    ECU: 08. Heater and climate[Archive (inactive)]
    Status: Confirmed
    U111300: Function limitation due to received malfunction value
    Bremsensteuergerät - bitte Fehlerspeicher auslesen
    ============13==============
    12850432
    Raw code: C41500
    ECU: 15. SRS
    Status: Test failed, Confirmed
    Communication with Vehicle Dynamics Control Module Implausible
    ============14==============
    13637376
    Raw code: D01700
    ECU: 17. Dashboard
    ============15==============
    01316
    Raw code: 0524
    ECU: 44. Power steering
    Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
    Brake control unit
    ============16==============
    00110
    Raw code: 006E
    ECU: 52. Front passenger door electronics
    Indicator repeater lamp in the exterior mirror housing on the front passenger side-L132; Front passenger side mirror indicator lamp-L132
    ============17==============
    01303
    Raw code: 0517
    ECU: 56. Head unit (MMI) (VW TP2.0)
    3 of your 4 ABS wheel speed sensors are faulty.
    Don't use cheap Chinese ones they don't work.
    Get proper Bosch or other suitable and compatible parts.
    If they are not the correct part they will physically fit, but the gap between the tone ring and hall effect sensor in the wheel speed sensor will not be correct and you'll get a fault.
    once all 4 speed sensors are working correctly and the faults don't return, you can work through any remaining faults.
    RunAutoParts sell the wheel speed sensors for Mk6 Golf. About $40-45 each for Vemu, Bosch or TRW.
    Run Auto Parts
    Sep 2024
    Brisbane qld
    Just ordered a full set of PAT abs sensors, ill let you know if this fixes the problem. Thankyou.
    Sep 2024
    Brisbane qld
    Hey, I took your advice and swapped all 4 abs sensors with quality parts and there has been no change so far. All codes and lights are still present, what do you recommend I do now?
    DTC report
    U0415
    Raw code: C415
    Status: Pending
    U0415
    Raw code: C415
    Status: Pending
    18255
    Raw code: 474F
    ECU: 02. Transmission control unit[Archive (inactive)]
    16352
    Raw code: 3FE0
    00287
    Raw code: 011F
    Rear Right Wheel Speed Sensor-G44; Rear right speed sensor-G44
    00290
    Raw code: 0122
    Rear Left Wheel Speed Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small
    00285
    Raw code: 011D
    Front Right Wheel Speed Sensor-G45; Front right speed sensor-G45
    00283
    Raw code: 011B
    Front Left Wheel Speed Sensor-G47; Front left speed sensor-G47
    04278
    Raw code: 0010B6
    12850432
    Raw code: C41500
    ECU: 15. SRS
    01316
    Raw code: 0524
    Brake control unit
    U0415
    Raw code: C415
    Status: Pending
    18255
    Raw code: 474F
    16352
    Raw code: 3FE0
    00287
    Raw code: 011F
    00290
    Raw code: 0122
    00285
    Raw code: 011D
    ============18==============
    00283
    Raw code: 011B
    ============19==============
    04278
    Raw code: 0010B6
    ============20==============
    12850432
    Raw code: C41500
    ECU: 15. SRS
    ============21==============
    01316
    Raw code: 0524
    Brake control unit
    Mornington Peninsula, VIC
    Double-check if there are any other fuses feeding the ABS, sometimes a smaller one is used for the sensors.
    Try testing the voltage at one of the sensor connectors, there should be some voltage of 5-12v with the sensor disconnected, and with the ignition on.
    The next place I would be looking is at the main ABS connector, check voltages and grounds. then check the connection between the sensors and the main connector.
    That should at least pinpoint if it's a harness issue, or the module itself.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Sep 2024
    Brisbane qld
    Quote Originally Posted by MIG View Post
    First off, thanks for the advice. And secondly all sensors and connectors are perfect, with each speed sensor reading and 11.8V. I then cleaned all the sensors and connections with nothing changing afterwards.
    I have nothing else to troubleshoot myself and I've now decided to had it off to a workshop to get an official diagnosis, then hopefully repair instead of replacement.
    I'll update this thread once I hopefully get this issue fixed.
    Dec 2016
    Did you happen to get this sorted?
    I was getting this error:
    Code:
    1 Fault Found:
    01130 - ABS Operation
                008 - Implausible Signal
    It turns out it was the ABS controller, I was still running the original problematic H35 unit. I swapped in both the controller and pump from a newer Jetta (H31) and it fixed the problem after some coding with VCDS.
    Swapping the parts was quite simple but bleeding the new pump was NOT fun!
    Not saying you have the same problem but let me know if you want a hand to do a VCDS scan or help troubleshoot.
