hi guys , after installing the tip, im racking my brain to think of ways to getting the cooling hose to not press against the tip, which im asuming is a normal thing for the tip instalation. has anyone conjured up ideas to somehow prevent this from happening. a few ideas ive had was A/ to saw off the end of it and get a longer rubber part of the cooling hose. though the problem with this is maybe the rubber will prematurally deteriorate being so close to the engine bay/
B/bending it somehow to get it away from the tip, though it would be bloody hard to manually bend it at the end. or C/ undo the "nut of doom"(you all know the one im talking about), bend it mid way along use nuts/washers etc to push the bracket away from the engine bay and get a longer bolt to fit.can someone please tell me are these just hair brained ideas? has someone actually solved this problem? or should i just be bloody happy and stop winging.
