Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: What to do in case like this?
    Nov 2008
    I was reading an article about the Toyota throttle issue in the USA, the article states:
    Toyota will also add a so-called smart pedal, software that cuts engine power any time both the accelerator pedal and brake pedal are depressed at the same time.
    Such software has already been adopted as a safety feature by a number of automakers, including Volkswagen, Audi, Porsche, BMW, Nissan and Chrysler, the companies said.
    Don't know for sure but the Tiguan probably has this system...
    2012 GTD, DSG, White, RVC, RCD510 Dynaudio, R LED Tails
    Sep 2009
    Harbord, NSW
    Re 'Smart Pedal' :It does and its a total pain in the bum if you 'heel and toe' whilst braking and changing gear. I'd love to be able to turn this 'feature' off.
    Anyway on topic - I would have thought that it could have been put in Neutral: unless the load on the gearbox was such that it couldn't disengage. Not sure how the autobox works, but a manual box under load is hard if not impossible to shift under load (no clutch)
    I can see how the electronics wouldn't allow him to drop down a gear to prevent over running
    The only other instance I've heard of this was truck driver somewhere (UK I think) who drove saying his throttle was stuck open and his brakes had failed trying to stop it. When they analysed the trucks computer and parts the driver had made the situation up.
    It'll be interesting what the outcome of this is
    Dec 2007
    I'm sitting on the fence on judging this one, because my tendency to analyse things has me crying B/S...
    I can believe that a car ECU could fail, effectively locking out all input signals such as "key is off", and keep the thing running at full clip.
    A Ford Explorer does not have drive-by-wire throttle, though, as far as I know, so in this case it would have to be a frayed cable preventing throttle return. But this is unlikely too, since there is always a spring on the throttle body to shut the throttle in case of cable disconnect. Maybe this jammed open, but he would have had to be using full throttle, the return spring would have broken and jammed itself fully open.
    In that case, turning the key off would work, and throwing the auto into neutral should also work, albeit the engine would probably over-rev and self-destruct.
    Then he was able to make phone calls while panicking - hmmmmm
    So will he get booked for driving dangerously, speeding, and using the mobile?
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
    Nov 2008
    QLD
    I saw the geek interviewed on TV. He was grinning and carrying on avoiding straight answers to the journo's questions. I'm calling on this. Not saying he didn't have a problem, just his "out co control, can't stop" scenario. As gerhard said, he was able to make multiple mobile calls while "running out of control".
    Aug 2009
    A follow-up article in The Age today -
    http://theage.drive.com.au/motor-new...1218-l0tv.html
    It doesn't seem to be a high priority for the police, but Ford have to wait.
    Aug 2009
    using the parking brake in an emergency
    Quote Originally Posted by Swallowtail View Post
    Yes it will work. Try it. Seriously... it is pretty effective too. It is designed to be able to be used as an emergency brake.
    Thanks Swallowtail for this information. I must have overlooked it when I first read the Manual.
    Joe
    Sep 2009
    QLD
    uuuuhum......................... BS!
    2010 Candy White TDI Auto, black leather, bi-Xenons + fogs, DVD plus other gadgets and gizmos to keep the kids quiet!
    Aug 2009
    South Australia
    This happened to me 15 years ago,darn scary
    Activated the cruise control and the car just kept accelerating,wouldnt slow down even when pressing the brake. Slipped the car into neutral and pulled over but the engine kept over reving until it reached 7000rpm.Shutting off the ignition and
    taking the key out didn't make any difference.Had to call the RAA.
