Arctra what gave you the courage to test the wading depth?
Not many Tiguan owners would do that I am unbelievably amazed![]()
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
That's pretty cool!! Any seepage, as that's well above the door sills !?
Have taken mine to about the centre of the wheels, which is about 350mm, but had a smooth concrete surface below me... My GF freaked out!![]()
What about the breathers for gearbox etc?
Very often the water damage shows later. I would be checking the oil in the diffs, making sure that it's not contaminated with the water.
Relocate your breather hoses and there is also drainage hose at the base of the air filter box, that should be relocated higher, if someone needs to drive their's Tig over the flooded areas. The hose has very simple one way valve which will still pass the water if submerged. Relocate it higher as well.
I felt I didn't have much of a choice. I had just driven a few hours to a dirt bike event and this was the last bit of the journey - where we were camping was literally 100m further on. There was plenty of "umming" and "ahring" before I finally bit the bullet and did it.
No seepage at all - I was well impressed actually.
Miro - you have me worried now. I have done a couple thousand km's since the crossing without incident, but if there's water in the diffs then there won't necessarily be any obvious signs that I am damaging the vehicle is there? Other than change the diff oil, what else should I do in case there is water damage?
Tiguan TDI, 6spd Tiptronic Auto
Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
Avg 7.63L/100km over 189,000kms
If you find that the water entered the diff, change all the oils (diffs, bevel gearbox, transmission). They all have the breathers and they aren't high enough. Relocate them to the highest point at the engine firewall.
