Results 1 to 10 of 20
Thread: Tiguan vs GTI?
    Tiguan vs GTI?
    Hi all,
    I've got a 2008 MY09 Golf GTI. Its a great little car, and the lease is running out later on this year.
    I'm tossing up between keeping it, or selling it and buying a new Tiguan (as I'd like to be able to tow a smallish c. 1000kg boat and trailer with it). My questions:
    • My research leads me to understand that the motor in the Tiguan 125 and 147 is identical, can anybody confirm
    • More importantly, if I buy the APR chip upgrade for a 125 Tiguan, how would it drive compared to my GTI? I'll obviously go and test drive the Tiguan to see if the chasis dynamics are acceptable, but in terms of acceleration - how would a chipped Tiguan compare to the GTI? Would it beat it? It seems to be 270kg heavier, but would be 189kw / 402 nm vs 147kw / 280nm
    • With the new 7 speed DSG - could this handle the ECU upgrade as easily as the 6-speed DSG without failing?
    It seems the 125 Tiguan with the comfort pack (or whatever its called, with the auto lights and wipers) and a ECU chip is amazing value, just would like to understand how it stacks up against the GTI power / acceleration wise - as would like a SUV body, AWD and a tow bar, but nothing slower than a GTI. Thank you all in advance!!
    Nov 2007
    Quote Originally Posted by Trogdor View Post
    Hi all,
    These threads almost always ends in tears ..... mostly because the Golf drivers have little understanding of what the Tiguans are capable of ..... and gets upset, shows their ignorance and insults somebody .... .... but anyway here is my perception of it and I have driven the GTI's quite extensively as well ....
    1. MK6 GTI (not the MY09 MK5) and all the TSI Tiguans have the same engines. 125 and 147 and 155 TSI's are identical, only the factory ECU programming differs.
    2. A 190kw/400NM Tiguan is much quicker than a stock GTI and in fact pretty much identical to a 190kw/400NM GTI ......
    3. Where the AWD adds weight, it also adds traction ..... so the extra 250kgs are offset by the traction advantage of AWD over FWD.
    4. Provided you sort out the suspension out on the Tig and add sticky rubber they will be relatively close in the handling stakes .... Tig superior in the really tight stuff where the AWD assists, GTI superior in the more flowing corners where grip not traction is more important.
    5. The Tig's 7spd DSG is far superior to the old 6sp DSG. It is the latest version of the DSG and can handle 550NM. Do not confuse it with the 7spd DSG in the Golfs that can handle only 250NM. They are entirely differnt gearboxes.
    So from my own experiences .... even a Stg 2 GTI cannot pull away from my Tiguan from point A to B ..... in the tighter stuff the Tig has to be held in to prevent it from running over the GTI, in the longer swooping bits, the Tig's extra weight and higher centre of gravity slows it down a little bit. As the ultimate Q-car the Tig is unbeatable. It is so much faster than what it looks and what people expect.
    As I've said before, unless you've actually driven a 190+kw Tiguan, you cannot actually make a comparison ..... whereas I've driven GTI's from stock all the way to Stg 3 ....
    Adelaide hills, SA
    ...and from my own experience Sharkie is the most reliable source that can give you the right answer and I can only confirm that the Tiguan handling is out of this world, which you will notice when testdriving it. Those who go to track days on rainy days would know that there is no competition between GTI and the Tig in wet conditions, it's a game over for GTI.
    Thanks guys, really appreciate that. Sounds like the Tiguan is a great car. I love my Golf but sometimes its a bit too small / unpractical, especially for the towing.
    Is there any difference between the suspension on a Tiguan 125 and Tiguan 147?
    Aside from "cosmetics" and internal comforts, I'm trying to figure out if there are any mechanical differences (except for the ECU of course) between the models.
    Sorry for what is probably a dumb question - what do you mean by "sort the suspension out", can it by done by factory options or needs to be aftermarket, and rough cost?
    Nov 2007
    Apart from the cosmetics (and the ECU), there is no (as in zero) mechanical difference between the 125 and the 147. Suspension is the same.
    In order to get GTI like handling, you will need to add aftermarket suspension. Most of us who have done this, have used the H&R Sport Spring set (about $800 fitted), which drops the body by 40mm, significantly firms up the suspension and reduces body roll. That with a rear swaybar (abour $350 fitted) makes it handle similar to a GTI.
    Bear in mind that the Tig as standard is the best handling small SUV out there, with a very good balance between handling and comfort, so drive 1 first to see if you can live with it stock before going down the suspension mod route.
    A good set of 18" or 19" high performance tyres also transforms the handling as the stock tyres are not very good at all from a handling perspective. It may be that upgraded wheels is all you would need.
    Nov 2008
    QLD
    shhh, don't let the GTI boys hear you saying that they're a "great little car" - ruin their street cred
    Seriously though, everything that sharkie has said. If you want an exceptionally handling, fast car with practicality, then I don't think you can go past the tig, with these minor mods. Which reminds me, what is it with XR6 owners that think they can out accelerate a Tig - I had to embarass another yesterday on the way home At least GTI owners seem to know to be cautious now
    Jul 2010
    Quote Originally Posted by clip View Post
    Know what you mean ... but you gotta watch out for those de-badged XR6 turbos.
    MY11 Tiguan 147TSI (SOLD)
    Nov 2008
    QLD
    Quote Originally Posted by aussietig View Post
    yeh the buggers, good luck to them though, I'd probably being the same.
    Sep 2012
    The world
    Tbh, I've never really got the comparison between standard and modified cars. Weve just bought a tiguan 2.0T and owned a GTI for about 3 years, the GTI is far quicker as standard, better handling, better braking and quicker accelerating, sory guys that near 300kg weight difference and higher rolling suspension really does effect the performance and fuel economy.
    Don't get me the wrong the tig is ace, love it but it really isn't a GTI even with the same engine. I think a stage one tiguan would make up for that weight disadvantage, but you'd need to upgrade the suspesion to stop the roll into the corners.
    My mate has a stage 1 GTI, and it really embarrasses the Tig... After all that weight disadvantage is like having a full car of people vs just a driver.
    Definitely interested in a stage one for the tig and gti, makes the 2.0T come alive.
