Not in Victoria specifically but this thread in MyTiguan shows how I did it some years back plus some more recent updates and may be of help
Fog Lights - myTiguan Forum
Derek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
Parts can be bought here:
Front Fogs
MY11 Tiguan 147TSI (SOLD)
Thanks for the information.. I have read the article before and you have done a good job with the setup.
I am trying achieve next step up by using central controller, new headlight switch and so on.....
I have seen an article for VW CC before but I am afraid the wiring to the controller can be completely different with Tig...
Has anyone done this before? or do you know any technician in Vic would know how to this?
Thank you in advance.
Cheers,
Ed.
Aussie tig have you used these guys on other parts, how's the freight been from the US supplier - reasonable? Think the fogs were a $300 option?, so works out more than orig, but maybe not much more if install self.
Noed - Have often thought fogs would be a nice addition. I'll be watching this thread with interest
Tiguan TSI Catalina blue, Manual
Firstly it may well have been a $300 option, but not after market unfortunately!
VAGLINK is based in HK. Usually their prices includes free shipping! But it appears not on these fogs.
Nevertheless, shipping from HK makes it economical for us (especially since their postage costs are ridiculously cheap).
I have bought many bits and pieces from them. From experience, all their parts are genuine VW or at least OEM, but made in China for VAGs built and sold in that market.
So just need to watch out and quiz them a bit more regarding fitment or part numbers, when it comes to certain parts.
For instance and just as a heads up, Chinese Tigs have a longer wheel base than Rest of World.
Learnt the hard way, when I purchased the Tiguan R door mouldings (with aluminium strip) that don't fit.
However they did give me a full refund via PayPal.
So equally, I would suggest double checking the part numbers on their fogs, particularly since NZTiguan has mentioned (in the other forum) two versions based on the angle of approach. We definitely need 18 degrees here.
Hi Aussietig,
I also bought the door trim, but i was informed prior purchase that the back door trim is longer due to chi-tig version. But I insist with the purchase and I am ready with cut and trim the sill. I haven't started as yet but soon enough when I got proper trimming tool.
Anyway, an update regarding the foglights. I try my luck by contacting different VW dealer around my area and they confirm that they are able to retrofit the foglights for 500-600 mark. All genuine part from VW with oem switch replacement as well. It will be same as factory fitted.
would anyone consider this expensive?
Cheers,
expensive compared to orig option cost, maybe you can have a go at bargaining with them to get somewhere near the factory option price. Of course it was $300 when we were looking at Tigs (almost 2 years ago) so you may want to check current option price to be fair. There are legimately higher costs for installing post factory versus in factory, but as a Volkswagen customer I dont think it is unreasonable to put some pressure on re matching the factory fit price (which they probably wont, but may come closer). @ $400 be starting to look pretty good, at $600 thats double the factory, think even they could accept that doesn't compare at all well. Could also argue VW should wear some of the 'responsibility', as many tig buyers have compromised on exactly what they wanted at ordering because of extended delays in delivery. I know if we could have got what we wanted in a reasonable time frame, we would have waited, but compromised a bit to get the car in a decent time frame. No complaints, but we would have gone with fogs if it had been easier to get
Well good luck mate! Cause the plastic lugs on the back are in the wrong spot and I imagine the aluminium strip would be hard to shorten and still look pristine.
But keep me posted on how it goes and looks!
Cause they actually told me not to bother to send it back to them, once they found out my shipping cost to return it (that I demanded they reimburse me).
The only reason I ordered fogs with my Tiguan was to fill the hole in the front bumper. In the last 2 years I have only turned them on twice for fun. Auto headlight do not work with fogs turned on. How about buy the fogs and install but don't connect them.
TDI tiguan in the drive. ParkAssist, comfort, fogs
Service every 15,000, new fault code every 7,500km
