Results 1 to 10 of 11
Thread: Tiguan 155TSI coding for RVC with module
    Apr 2017
    Urrbrae S.A.
    Blog Entries
    1
    Hi out there,
    Can anyone with a similar Tiguan fitted with, RNS510 nav head unit, OPS sensors and retro fit OEM 'highline' reversing camera with trajectory module in boot, send me a copy of their complete printed out codes as saved when using a cable. I have had Solitair set it up for me but still no camera, just a blank screen showing OPS on left and a space where the camera shot should be. It maybe that my module 5NO 907 441 A may be faulty. So before buying another I'd like to confirm the coding. HERE IS MINE: note 6C is not switched on (nor does it help) the low line camera is on in NAV
    Chassis Type: 5N (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 4C 4F 52
    53 56 62 69 72 77
    VIN: WVGZZZ5NZCW019425 Mileage: 83540km-51909miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    4C-Tire Pressure II -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
    Part No SW: 5N0 919 475 D HW: 1Q0 919 475
    Component: PARKHILFE 4K H03 0045
    Revision: -------- Serial number: 32901123700033
    Coding: 318102
    Shop #: WSC 01324 020 00200
    ASAM Dataset: EV_EPHVA14VW3680000 001005
    ROD: EV_EPHVA14VW3680000.rod
    VCID: 3A7CAAC7BD4C3EEE53-806E
    No fault code found.
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 L HW: 1T0 035 680 D
    Component: RNS-MID H61 5269
    Revision: AB001001 Serial number: VWZ6Z7L9278046
    Coding: 04010440040000A0000C
    Shop #: WSC 40550 002 1048576
    VCID: 377AB3F3865E2386AC-8062
    Subsystem 1 - Part No: 7L6 919 859 G
    Component: AUNZ V8 8207
    No fault code found.-------------------------------------------------------------------------------
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
    Component: BCM PQ35 M 011 0048
    Revision: BC011001
    Coding: 46180A3BE02518C0C00800C0340081E449510088536D8D6064 8040200040
    VCID: 3B72AFC3BA7607E648-806E
    Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
    Component: Wischer 22081 013 0203
    Coding: 009795
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 120711 05 54 0403
    Coding: 02304D
    No fault code found.Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 K HW: 1K0 907 951
    Component: J533 Gateway H40 1620
    Revision: H40 Serial number: 120811F1001665
    Coding: 356003
    Shop #: WSC 00000 1008 480334
    VCID: 3878B0CF8B402CFEA5-806C
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    Apr 2017
    Urrbrae S.A.
    Blog Entries
    1
    OK I have changed the cable, no difference, I bought a new trajectory box, still not working. I note the solitair did not turn on the 6c in the can bus. I have done that but still no picture from the camera. Here is the letter I ahve sent to the suppier of the trajectory box (they are both the same so in time I will have one for sale as well as the cable to anyone who can help out)
    I have fitted this trajectory box to my 2011 VW Tiguan 155Tsi, with the genuine cable and a boot latch camera 5no 827566 c. I had previously added the VW RNS510 head unit part number 1TO 035 680 L, HW 1TO 035 680 D, component RNS-MID H61 5269with a non genuine mobile phone bluetooth kit. The vehicle has factory fitted reversing radar beep, that shows on the headunit screen. With the VCDS cable I have turned on 6c (back up camera) in the canbus 19, Vag No 7NO907 530 K, HW: 1KO 907 951. I have no image on the screen after rebooting the head unit. On scanning for errors my vehicle has a fault the can bus J533 gateway H40 1620 cannot communicate withe the trajectory box J772 gateway H40 1620. F fault found: 02873- control module for back up camera (J772), 004 - No signal/ communication. fault status: 01100120.
    The radio 56 and Nav 37 have the same fault recorded,
    Address 6c: back up cam. Cannot be reached.
    Any ideas as to what the fault might be?
    I have 12 volt power at the trajectory box, and approximately 4 and 8 volts on the can bus 'high' and can bus 'low' at the trajectory box so am confident that the wiring harness is connected.
    Any help greatly appreciated as I doubt that the unit is faulty.
    Greg Moore
    What pins are the 6c rvc module connected to at the canbus gateway?
    Rvc connects to the infotainment bus.
    Apr 2017
    Urrbrae S.A.
    Blog Entries
    1
    I followed the colour coding of the wires coming out of the trajectory module cable and soldered them to the wires in the cable at the back of the head unit. This harness is the wiring addition to fit the bluetooth phone module between head unit and original vehicle harness. Power to cable (module) was red with blue trace to pin 15. can plus was orange with purple trace pin 9. can - was orange brown on pin 10. P.S. here is the response from the supplier "Hi! My friend, according to our technical staff analysis, your car model circuit is likely to have problems."
    Quote Originally Posted by mazzamoore View Post
    You need actual wiring diagrams.
    Hit me up on pm with year and model of your car
    Apr 2017
    Urrbrae S.A.
    Blog Entries
    1
    Tiguan 2012MY, build date sept 2011, model 5N2 version 2M9
    Infotainment pins at the canbus gateway are:
    Pin 10 can low
    Pin 20 can high
    So you need to tap these wires and connect the 6c highline module can connections there.
    Apr 2017
    Urrbrae S.A.
    Blog Entries
    1
    Tiguan 155TSI coding for RVC with module-img_3683[1]-jpg
    Thanks for researching this for me. I am a little bit confused am I looking at the infotainment plug?
    Here is the photo of the rear of the radio head. Pins 9 and 10 are labeled can high and low. There does not seem to be a pin 20
    You can connect it there at the radio, or at the canbus gateway. The wires go between the two.
    Apr 2017
    Urrbrae S.A.
    Blog Entries
    1
    Three Cheers for Kamold, at last sorted.
    I had added the can high, can low and taken the positve from the cable that has been inserted between the radio head and harness for the mobile phone bluetooth connection.
    All I did was to remove those tap ins and redo them on the original car harness. A warning to those in the future - tap into the factory harness.
    So I now have a spare harness and trajectory box 5NO 907 411 A, all you need is the camera to suit your VW, Passat etc.
    Greg
