Quote Originally Posted by Bambazonke View Post
Hi Suffolk your assumptions are correct, I took my main power supply off the rear cigarette lighter socket in the boot. The wire was white with black stripe I think. The other wire at the socket is brown for earth.
The two wires you need to be careful with is the reverse wires which are located on the RHS of the boot behind the side storage flap. There are 3 wires one brown and two blue with black stripes. One wire supplies power to the reverse lights and the one to tap into for the RVC. The other supplies a signal back to the CANbus re the status of the lights.
Be prepared to have sore fingers prying off the panels and be very patient in taking them off and back on and follow CADman's advice with respect to the order of removing them and putting them back as I found out to my expense as I took a couple of days doing mine and forgot the order of removal
Hi
You say" The two wires you need to be careful with is the reverse wires which are located on the RHS of the boot behind the side storage flap.
There are 3 wires one brown and two blue with black stripes. One wire supplies power to the reverse lights and the one to tap into for the RVC. The other supplies a signal back to the CANbus re the status of the lights.3 wires in the RHS panel".
But you don't say what color wire goes were !.
cheers
