Results 1 to 10 of 106
Thread: Evilz 2015 Tiguan 155TSI R Line
    Quote Originally Posted by Evilz View Post
    Has anyone try to install front door puddle/Warning lights?
    Door warning lights yes done to Tig1. It's a very easy mod - get all the bits from bold-sport: Bold-Sport.com :: Door Warning Lights Housing
    Just requires a simple bit change in the coding and you're done!
    I haven't done the mirror puddle lights but these will be very similar to the Mk6 Golf: Bold-Sport.com :: Mirror LED Puddle Light Housing - Golf VI
    There's a DIY for it if you search on Google but does require cutting out the bottom of your mirror housings so is not reversible....
    Feb 2015
    Sydney, Australia
    Hi Tigger73,
    DIY found, wil try to do the warning lights for the doors this weekend for now. Seem like the puddle light will require alot more work in cutting and installation time. Got a big weekend ahead of me, gona get the Tig tint and if possible APR tuning as well. : ) Will update you guys later.
    Oct 2010
    Puddle lights can be purchased here: Online Shop OEM VW Sharan Tiguan rear-view mirror turn signal lights according to ambient light 5N0 949 101/102|Aliexpress Mobile
    Very easy install, only had a problem coding these puddle lights and door warning lights together. But I finally
    Figured it out and loving the light output, especially with led globes.
    You will also need replacement door clips.
    Feb 2015
    Sydney, Australia
    Are you sure it will fit into the 2015 tig? Also what sort of coding you need? I was trying to install the warning light for the door tonight, after taking it off then realise the wiring pin is double clip. Where it should be a single clip to fit in the connector, now i have to get some right clip wiring before installing it. Also can anyone tell me where i can source the VCDS/VAG software for coding please.
    Feb 2015
    Sydney, Australia
    Progress tonight.
    I have also installed the DV+ T9351, NGK Iridium IX (BKR7EIX) and R8 coils, speaking of which i totally forgotten to take to photo of it. . Also try to install the LED HID light headlight but failed, seem like there would be some rewiring and coding needed too. Just installing the headlight is easy, but i thought is plug and play..... which is not. Anyone got any ideas about this DIY?
    The airbox and wastegate only making minimal acoustic sound and performance wise i can feel that the car is definitely smoother and happier from start to high rev. But again i havent been driving it too hard (6k rev on testing after installation), since the pistons is still new and not run in yet. Im trying to get the tuning done on next week (if i can book in) and will see how much different it gona be after.
    Attached Thumbnails Attached Thumbnails Evilz 2015 Tiguan 155TSI R Line-image1-jpg   Evilz 2015 Tiguan 155TSI R Line-image2-jpg
    Evilz 2015 Tiguan 155TSI R Line-image3-jpg   Evilz 2015 Tiguan 155TSI R Line-image4-jpg
    Evilz 2015 Tiguan 155TSI R Line-image5-jpg
