Results 1 to 7 of 7
Thread: Can I code the number of flashes for lane change indicator?
    Currently flashes 3 times, I'd like 4. Can this be coded?
    09 Polo GTi "Elke" | APR DV1 | H&R 35mm | Bilstein B8 | Remsa Pads | Pioneer |
    Mar 2015
    Torrens ACT
    I do recall seeing the somewhere so I think the answer could be yes.
    I'll research but expect some of the VW Geeks to come up with the laser sooner.
    Dinah
    Jul 2007
    Brissy
    From Ross Tech wiki
    VW Golf/Jetta/Bora (1K/5M) Tweaks - Ross-Tech Wiki
    Comfort Turn signals may be turned On -or- Off via coding. The number of flashes cannot be adjusted.
    I assume this applied to Tiguan as well.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Pacific Paradise QLD
    Can be in a B7 Passat as mine were 3 and I reset them to 5 Gets done in VCDS Cant remember which module though
    Oct 2014
    So, VCDS Tweak
    VCDS > Select > 09 - Central Electronics > Adaptation - 10 > Channel 31
    Attached Thumbnails Attached Thumbnails Can I code the number of flashes for lane change indicator?-1-png   Can I code the number of flashes for lane change indicator?-2-png
    TIGR
    2017 162TSI R-Line Tiguan -
    Tungsten Silver | DAP | APR Stage 1 Build thread: https://goo.gl/YNgixR
    2015 155TSI R-Line Tiguan
    Build thread: https://goo.gl/sEqISR
    Thanks TIGR 5 sounds even better
    Quote Originally Posted by flashpixx View Post
    Ive got 5 and I wish I had only done 4 5 is just a bit long
