Quote Originally Posted by lunchboxGTI View Post
You can do something like this.
Adding line convertors to RNS-510?-image-jpg
I got a eBay cable designed to tap in a Bluetooth kit (the top cable in the first picture is how it comes) and turned the speaker out lines into RCA plugs . (Lower cable and second picture)
Then using VCDS change the stereo setting to "sound system" for amp output.
This allows you to run RCA cables to the amp and eliminates the need for a line out box or a amp that takes speaker line in.
Thanks for that option, I'm guessing that negates the use of the LOC then? I already bought a "decent" one so want to use that. It also has a remote turn on lead for the amp as recommended by Ramee above so it senses an audio signal then sends the all important 12V to the amps. This is the LOC I have.......
LCQ-1 - Six Channel Line Output Converter with Equalization and AccuBASS
Adding line convertors to RNS-510?-x161lcq1-o_front-jpg
