Results 1 to 10 of 30
Thread: Roof Console - Three-Button Module - Reprogram
Brian916 Roof Console 22-03-2011, 07:53 PM
Corey_R They're for the Bluetooth.... 22-03-2011, 07:57 PM
Brian916 Bluetooth.... OK... obviously... 22-03-2011, 08:02 PM
orkers Don't get too excited: If... 22-03-2011, 08:47 PM
Brian916 Oh. They're useless then. I... 22-03-2011, 09:14 PM
markwid Gold. LOL. Hmnn. Wonder if... 22-03-2011, 10:47 PM
Boldy Roof Console - Three-Button... 12-07-2011, 11:21 PM
Corey_R I've moved this to the VW Car... 13-07-2011, 11:03 AM
futori I've tried to do it through... 13-07-2011, 02:01 PM
bushnut this should be set up when... 13-07-2011, 08:55 PM
Boldy That would be great, thanks... 13-07-2011, 09:39 PM
jefalijas Changing VW ASSISTANCE and VW... 11-08-2011, 07:06 PM
futori see this thread... 11-08-2011, 08:06 PM
grtuned If you have VCDS select... 11-08-2011, 08:28 PM
Corey_R Thanks grtuned Now, if a... 11-08-2011, 08:34 PM
jefalijas It ask to enter the phone... 13-08-2011, 05:39 PM
Boldy Take a look at String to... 15-08-2011, 05:27 PM
grtuned I have done it on 2011 golf... 16-08-2011, 08:47 PM
grtuned I have tried using vag com... 18-08-2011, 10:32 AM
gokartgti 3 button vagcom 20-10-2011, 09:23 PM
jimmy glad to hear it. I should... 12-02-2012, 08:46 PM
    Jul 2011
    Berwick, Vic
    Take a look at String to ASCII chart, ASCII to decimal convertor, String to decimal converter, string hexadecimal / hex conversion , though I can't see it working with just 7 digits as we'll need 10.
    Jul 2011
    I have done it on 2011 golf and it worked but did not ask for
    numbers to be put in as hex input. I suspect different phone kit versions to blame I have not had time to check but ill do it tomorrow and
    post out come Possibly add australian area number into the equation????
    Jul 2011
    I have tried using vag com and as jefalijas says a hex code is required. i have tried multiple hex combinations but vag com will not allow
    number to be stored i suspect vag com communication issue it may be fixed during an update who knows??
    But what i have found is if you ask VW dealer to do this it will store a number using there machines, This will be a cost to whoever chooses to have it done...
