Results 1 to 6 of 6
Thread: RNS510 - Reverse Camera Not Displaying
    Jan 2010
    Has anyone had a problem with the Reverse Camera not displating in the RSN510?
    Is there an VAGCOM update to correct the problem?
    GTI MKVI DSG|18" Detroit|Leather|Park Assist|RVC|MDI|RNS510
    Feb 2009
    If it's a factory fit / dealer fit then why wouldn't you just take it back there to get sorted out?
    Jan 2010
    It was factory fit. I discovered it while doing a delivery check. The salesman took it around to the service guys and they have trold me that it is a problem with the code. They have also said that they are waiting for an update from VW.
    What I was interested in is if anyone who has recently taken delivery of a new VW that has RSN510 and Reverse Camera fitted or maybe who has installed/updated to the latest code/firmware, have they had the same problem.
    Is there an update available that fixes this problem?
    I am NOT doubting or having a go at the dealer but there maybe someone out there who knows about this.
    Jul 2009
    Singapoe, Singapore
    Quote Originally Posted by JAYDEE View Post
    Hi,... i've a mate with a Golf 6 GTI with RCD510 and a reverse camera (factory fitted) which was working.
    He recently upgraded to a RNS510 and had the same issue as you.. i.e the reverse camera didn't show up on screen on the RNS510.
    I took a look at it for him.. and did some VAGCOM check... and yup.. looks like it is indeed a problem with the coding.
    I fixed the coding via VAGCOM and voila.. it's working now.
    His RNS510 is on firmware 268x.
    Cheers!
    Jan 2010
    Quote Originally Posted by hannson View Post
    Cheers!
    Thanks for that info hannson.
    I have just had word from the dealer that they have found the problem with my GTI. It turns out that there was a short in the camera wiring.
    Problem is now fixed.
    Still interesting that you were able to fix your friends GTI with a code fix. Must check what firmware version I have.
    Jul 2009
    Singapoe, Singapore
    no worries
    glad to hear your dealer is sorting things out for you...
    in my friends Mk6 GTI.. what happened was.. he had a RCD510 with the factory fitted camera... he swapped out his RCD510 for a RNS510.. and that camera stopped working....
    it turns out there was a VAGCOM coding that we had to perform in order to get it going again (fortunately there were no hassles with wiring)
    All's good
    Cheers!
