Results 1 to 10 of 24
Thread: RNS510 installed, 2 problems....
    when you used the credit card - were you able to 'move' the bubbles or did they appear deeper under the surface ?
    If you can move them - it's like a protective film for the screen has been left on...
    ...is it worth trying to prick it with a pin right in the lower left corner ? - dont do it if your not sure !! - just a thought (committed to text)
    MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
    MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
    Mar 2011
    Yes the bubble moves but I don't think it's the protective coating because the installer peeled that off prior to installation.
    As the two smaller bubbles dissapeared I'm hoping that the last one will too given a few days. Fingers crossed anyway !
    Jul 2010
    Quote Originally Posted by Jaap74 View Post
    Quite frankly, looks a bit dodge!
    Never heard of bubbles on an actual backlit screen before.
    FWIW, I'd be returning it for a refund or exchange.
    MY11 Tiguan 147TSI (SOLD)
    Jun 2008
    South Coast N.S.W.
    Quote Originally Posted by aussietig View Post
    I agree with aussietig if it doesn't have a plastic protective cover on the screen then it has a problem with the LCD display, if possible return it as faulty. I'm a little surprised that the installer didn't notice this and if such he should have advised you it had a problem rather than continuing with the install As far as the bluetooth issue I would suggest that the voice volume needs adjustment from within the unit settings.
    Russ
    2005 Subaru Outback 3.0 R Premium
    Mar 2011
    I wonder what my chances are of the Lithuanian seller sending me another unit then paying the freight of the damaged one back ?? I shall ask and report back.
    As for the Bluetooth there are no settings within the RNS 510 for it as it's not the Premium Bluetooth.
    Jun 2008
    South Coast N.S.W.
    There is a setting for telephone volume, you'll find it under SETUP / VOLUME SETTINGS / TELEPHONE VOLUME. I don't know if this will help you or not but it might be worth a try
    Russ
    Mar 2011
    Quote Originally Posted by Russ59 View Post
    I don't have that option under SETUP :
    Perhaps as my Bluetooth is different to yours ?
    Try under the Tone menu...
