Wonder if its got the Regensburg syndrome
Volkswagen RNS 510 Regensburg syndrome | my-gti.com
Yes same disk for skodas, vw
I took it to the Skoda garage and they tried their firmware disc and new maps (for free!) But no luck, still no GPS lock. I have been running the new aerial for a while as the garage suggested it would be the that.
At this stage I might cut my losses and order a new unit, any suggestions for the best place to by a Columbus unit? And also can the vw RNs 510 be used in a Skoda, will it have the same functionality?
And lastly is anyone looking for a perfect condition Columbus unit that does not do GPS....
Sent from my Nexus 5 using Tapatalk
You are wasting your time taking it to a dealer You get far better help on here off the likes of Kamold etc.
Did you go to the link i posted and read that. Is it what your unit is doing.
As far as has been said on here they are all virtually identical apart from the faceplate surround Maybe the aerial is faulty . You could buy a cheap one off Ebay and try it before buying a new unit.
Yeah I have previously checked that syndrome out but it is not showing those symptoms.
If you mean GPS aerial I have tried 2 different ones plus the factory one in the car.
I followed karmold advice and reburnt the firmware disc with 1x using his recommend app and we tried the factory Skoda firmware disc at the garage.
I have spoke to the local euro car independent workshops as well plus read every link on the first 10 pages of a googles search on RNs 510 no fix/no satellite etc.
Is the an internal module that can be replaced instead of the whole unit? I may google that as last resort.
Thanks for all the ideas so far.
Did you try this
Settings/ factory reset/ scroll down to navigation and navigation memory.
Tick them and press reset
Other than that you could reset the whole unit back to factory from that menu but i guess you would lose all settings and maybe music etc
Yep done all the resets possible, think I will send it for repair at this stage, guessing the GPS board is screwed.
The difference between it working and not working was a dsg transmission service, I am guessing there is nothing they could have done to screw it up?
I have purchased 2 RNS GPS antenna from these guys and a friend has purchased another also. All perform faultlessly.
get4less_shop on eBay
for the price of an antenna...I'd try that first
