Looks like you haven't coded the bluetooth correctly. Did you input the 41,21 and 20 for the coding?
Can someone help me out with this? I bought the 9w7 bluetooth unit from ebay and have installed and configured it. Everything works fine. I paired it to my blackberry, I can dial out using the RNS 510 and the MFD. I have transferred the contacts to the telephone book and the microphone works fine. However the VAG COM returns this fault below. Any advise is much appreciated.
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669880785
Coding: 0A00000000010100
Shop #: WSC 00000 000 00000
ASAM Dataset: UHVNA A01009
VCID: E2C123C244DF
3 Faults Found:
9455633 - Telephone Microphone
B1048 11 [009] - Short to Ground
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 115
Mileage: 31070 km
Date: 2014.14.01
Time: 11:01:09
9458195 - Control Module for Cellular Telephone
B1052 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 115
Mileage: 31070 km
Date: 2014.14.01
Time: 11:01:09
13636352 - Control Module Not Coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 115
Mileage: 31070 km
Date: 2014.14.01
Time: 11:44:59
End ---------------------------------------------------------------------
[/B]
__________________________________________________ _____________
2014 GTI PP/Pure White/DAP+Leather
2010 TSI 118/DSG/Reflex Silver/SP+ACC/Sunroof/Dyna/MDI/SatNav /PA+RVC
Rob
These are the codes I can see with the VCDS:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
I do not see the 41,21 and 20. My vehicle is a Golf VI 2010 TSI 118
Any idea why??
I found a fix from this article. Wiring issue.
Bluetooth in MY11 GTI Works with IPhone !
