Results 1 to 5 of 5
Thread: RNS 510 9w7 Bluetooth install microphone fault
    Feb 2010
    Can someone help me out with this? I bought the 9w7 bluetooth unit from ebay and have installed and configured it. Everything works fine. I paired it to my blackberry, I can dial out using the RNS 510 and the MFD. I have transferred the contacts to the telephone book and the microphone works fine. However the VAG COM returns this fault below. Any advise is much appreciated.
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 HW: 5K0 035 730
    Component: TELEFON H09 1020
    Revision: 1B001001 Serial number: 00007669880785
    Coding: 0A00000000010100
    Shop #: WSC 00000 000 00000
    ASAM Dataset: UHVNA A01009
    VCID: E2C123C244DF
    3 Faults Found:
    9455633 - Telephone Microphone
    B1048 11 [009] - Short to Ground
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 115
    Mileage: 31070 km
    Date: 2014.14.01
    Time: 11:01:09
    9458195 - Control Module for Cellular Telephone
    B1052 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 115
    Mileage: 31070 km
    Date: 2014.14.01
    Time: 11:01:09
    13636352 - Control Module Not Coded
    U1013 00 [009] - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 115
    Mileage: 31070 km
    Date: 2014.14.01
    Time: 11:44:59
    End ---------------------------------------------------------------------
    [/B]
    __________________________________________________ _____________
    2014 GTI PP/Pure White/DAP+Leather
    2010 TSI 118/DSG/Reflex Silver/SP+ACC/Sunroof/Dyna/MDI/SatNav /PA+RVC
    Jan 2010
    North Shore
    Looks like you haven't coded the bluetooth correctly. Did you input the 41,21 and 20 for the coding?
    Feb 2010
    Quote Originally Posted by Rob Burns View Post
    rob, thanks for your input but what do you mean by 41,21 and 20? I followed the instructions as posted in the forums here. I will get the details and post it tomorrow.
    Feb 2010
    Rob
    These are the codes I can see with the VCDS:
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    I do not see the 41,21 and 20. My vehicle is a Golf VI 2010 TSI 118
    Any idea why??
    Feb 2010
    I found a fix from this article. Wiring issue.
    Bluetooth in MY11 GTI Works with IPhone !
