- does the RCD330 work with OEM reverse camera and sensors? Yes I have the oem camera and it works great. You need an adaptor and if you are handy with electrical work (I wasn’t) it is pretty straightforward.
- does the RCD330 work with Dynaudio? Yes- over at mk6 forum all they had to do was disconnect and connect their battery for it to work
- I assume it's a direct plug and play? Yes mostly, VCDS coding is pretty easy.
- I assume GPS is redundant with carplay/android play? Was skeptical about apple maps but if you are in a major city, works perfectly
- can you get a unit that does both android and apple? (Work phone is iPhone and personal is Samsung)
Head over to the golfmk6.com forum, they have a pretty epic thread and a number of people have changes from RNS510 to this. I highly recommend it- Bluetooth quality and functionality is fantastic
