I can't help, but does that unit allow the factory RVC to plug into it?
Hi All,
I am a little confused, I have recently installed a Desay SV 6RD035187B in my Jetta and was wanting to update the firmware. I've read online that you cannot update the firmware on the Desay SV version however some sources say that you can on the Desay Model B. mine does say B on it but it also say SV ?? so I dont know ?? anyone here have the same unit ?
mine:
Current 2023 T-Roc R-Line 140TSI | Past 2015 Jetta Trendline 118TSI
thanks Jake!
I will probably proceed with the purchase and see how it goes.
Does it work with iOS 13 latest versions normal?
is it possible to share the update link that you have applied to your RCD 330?
Thanks again Jake
Regards,
Karim
no issues with latest iOS, just make sure you use a good cable.
updates : Firmware : RCD_330
thanks (Y)
regarding the updates, thats a huge list of files!
is it possible to specify which one you have downloaded?
thanks, and stay safe of that #corona![]()
hey,
sorry for nagging
is it possible to specify which link / file you have downloaded?
thanks again
