Results 1 to 10 of 10
Thread: Desay RCD330 updating firmware ?
    Jun 2015
    Liverpool, NSW
    Hi All,
    I am a little confused, I have recently installed a Desay SV 6RD035187B in my Jetta and was wanting to update the firmware. I've read online that you cannot update the firmware on the Desay SV version however some sources say that you can on the Desay Model B. mine does say B on it but it also say SV ?? so I dont know ?? anyone here have the same unit ?
    mine:
    Current 2023 T-Roc R-Line 140TSI | Past 2015 Jetta Trendline 118TSI
    May 2007
    I can't help, but does that unit allow the factory RVC to plug into it?
    Jun 2015
    Liverpool, NSW
    Quote Originally Posted by ope126 View Post
    i dont' have one but from what i've read only AV Cameras will work using an adapter.Desay RCD330 updating firmware ?-s-l300-jpg
    Jun 2015
    Liverpool, NSW
    Update... took the risk and it worked !!! successfully updated from version 0317 to 0318 on the Desay SV Model B.
    Desay RCD330 updating firmware ?-img_6771-jpg
    i was surprised that after the update i didn't loose my radio preset or BT - Phone pairing.
    Mar 2020
    Cairo
    I have RCD 510 and thinking to switch to RCD 330
    Quote Originally Posted by jake85 View Post
    Hi Jake,
    is it worth the change from RCD 510 to RCD 330?
    am thinking mainly for the apple carplay part
    thanks
    Karim
    Jun 2015
    Liverpool, NSW
    Quote Originally Posted by keyada View Post
    Hi Jake,
    thanks
    Karim
    I've never had the RCD510, i upgraded from RCD310 to RCD330.... but so far its been great.... Apple CarPlay works great !
    Mar 2020
    Cairo
    thanks Jake!
    I will probably proceed with the purchase and see how it goes.
    Does it work with iOS 13 latest versions normal?
    is it possible to share the update link that you have applied to your RCD 330?
    Thanks again Jake
    Regards,
    Karim
    Jun 2015
    Liverpool, NSW
    thanks Jake!
    Thanks again Jake
    Regards,
    Karim
    no issues with latest iOS, just make sure you use a good cable.
    updates : Firmware : RCD_330
    Mar 2020
    Cairo
    thanks (Y)
    regarding the updates, thats a huge list of files!
    is it possible to specify which one you have downloaded?
    thanks, and stay safe of that #corona
    Mar 2020
    Cairo
    hey,
    sorry for nagging
    is it possible to specify which link / file you have downloaded?
    thanks again
