I have just installed an OEM dumb RVC (only has the static lines) in my Tiguan . I bought the nearly new rcd 510 Bosch head unit off eBay for $300 plus postage in february. VCDS software identified the unit was assembled in may 2011. The rcd 510 delphi unit made for the Chinese market, appears to have 2 versions of these units as well the later one is known as the RCd 510 plus+ and it has the camera socket and a usb output that supports an ipod i have seen it advertised on ebay for USD 500. I Had a few issues getting the camera to work as there are two versions of the RVC and each have different software activation procedures but very simple once you know how.
The basic OEM unit can be sourced off eBay from about usd280 upwards and the advanced unit for usd500 upwards as it has an extra box of tricks to generate your moving line into a parallel or perpendular parking spot so yes it can be done and I have a picture to prove it!!!!
- You may not post replies
- You may not edit your posts
Forum Rules
