Results 1 to 10 of 12
Thread: HID conversion
    Jul 2011
    AU
    HID conversion
    Hi fellow enthusiasts,
    I have a blown foglight lamp and was looking for replacements. Due to the halogen foglight lamps being notoriously bad for having a short life span, and also due to me being the tinkering type, I am considering installing a HID conversion kit instead. Being an electrical engineer who does a lot with lighting, I am familiar with most of the technical aspects, however I was wondering whether anyone has had any actual experience with the conversion kits that are available?
    I do not want to buy rubbish, I want to make sure what I'm buying is good quality and is going to last. The kits I have seen on Amazon.com are from JLM and Kensun. They sound Korean or something, which does concern me a little, but I have been unable to find anything from the big name european manufacturers like Osram or Philips.
    All informed feedback and comments are appreciated.
    Jun 2009
    Why not go the led type instead?
    Jul 2011
    AU
    I have tried some LED ones, and I am still considering that option. The ones I tried previously had about 100 very small SMD LED chips per lamp. The problem with them is that there was no heat sink, and heat is the number one enemy of LED with regards to performance and life span - so these particular LED's began to rapidly die, one chip at a time. After 6 months about 70% of the chips were dead. I have seen some others on amazon which have fewer, higher powered LED chips and have an aluminium body, some even with an external heat sink. These are probably much better. In either case, I'll have to buy an inline resistor/error decoder as the MFD showed errors when I used the LED types previously.
    Jan 2011
    Brisbane - QLD
    MINI Cooper S Clubman - FWD
    Jul 2011
    AU
    Yeah they look alright.
    I was also looking at these. I like the look of those substantial heat sinks. That's really what's required for high powered LEDs.
    HAMMER H8 New BMW White 32W 7000K Angel Eyes LED Halo Bulbs Special Offer 2-pc Set:Amazon:Electronics
    Mar 2013
    Chinchilla
    I have fitted HID's from EZHID to a VE Commodore. Haven't looked for a VW suitable set but I have to say they were absolutely amazing with regards to visability.
    I didn't fit fog lights, just high/low beam. 35w and 55w from memory.
    HID Kits All In One
    I got 4300K as these have more light and are whiter.
    I have heard of people using ebay kits with success.
    Jul 2011
    AU
    Thanks for your input alex. Do you know whether there has been any problems with the commodore conversion since the install? How long has it been going?
    I will go have to find out what colour temperature my headlights are so that the fog lights match (I have factory fitted xenon HID headlights)
    Jan 2012
    if you go down the HID path, youll need to disable turning fog lights and the coming home/leaving home (for fog lights) feature as they both fade the fog light.
    ebay kits are fine, also jaycar kits are pretty much the same - just no delivery times
    been running a few of them for several years now with a few cars.
    Jul 2011
    AU
    With my car the coming/leaving home function just operates the headlights and LED DRL's, and I don't have the turning foggies, I have the dynamic HID headlights that turn. But cheers for the input.
    I just want to make sure I get something quality. Don't want my car to catch fire or the ballast to fail after 6 months or something. If I go with a well known brand like Osram or Philips etc, I know it will be quality.
    Mar 2013
    Chinchilla
    Quote Originally Posted by Tobes_WIR35 View Post
    I had it for 2 years and they were going strong. Still as good as the day I bought them.
    I steered away from HID foglights because yellow is used for a reason, you can see better in actual fog (which there is sometimes where I live).
