Results 1 to 6 of 6
Thread: Getting stereo out to check OBDII port
    May 2010
    Perth
    Hi All,
    Apparently my OBDII port (located under the climate control/dual DIN dvd screen) doesnt work in my Bora.
    I want to pull out the head unit so I can check for dodgy connections etc.
    Any hints or tips to make my life easier?
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    May 2010
    Perth
    anyone?
    Dont want to go about ripping out half my dash if i dont need to...
    Feb 2007
    Get stuck in, its not hard. Take so you dont damage anything. Who told you that it doesnt work?
    MK1 GLS 3door
    A4 B7 2.0T
    May 2010
    Perth
    mechanic who uses VAGCOM
    i'll be testing myself with vchecker that arrived today too (need it to know if the wire's im testing has fixed it). Apparently its a common issue with aftermarket headunits affecting the Kline
    May 2010
    Perth
    just checked and yeah its not readable.
    Where do I start with getting access to that area?
    Jan 2007
    brisbane QLD
    depends what stereo you got... what happened to the original K-Line?
    you could pull the climate control head out too
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
