Results 1 to 10 of 580
Thread: Discover Media retrofit
    Nice one Kamold Would you mind giving a breakdown of the part numbers etc if we wanted to do this ourselves? The hardware modification for the component protection sounds like it's the trickiest part.
    How does it compare with the Composite Media (~$1k with component protection removed) and RCD330 Plus (~$200-300) units?
    MY10 Golf Mk6 103TDI DSG Candy White | Revo Stage 1 ECU Tune | 18" Talladegas | GTI Front/Rear/Exhaust | R LED Taillights | GTI Steering Wheel | VW Discover Media | Focal IFVW Front Speakers | Mk7 Climatronic Panel |
    Jan 2017
    Quote Originally Posted by moda View Post
    Don't touch the RCD330 unless you're after a budget install. The sound will be a downgrade from your factory unit (depending what you have), and you'll forever find bugs. I pulled mine out after a little over a week and went with a Composition Media install.
    CM vs DM is at a very basic level a choice between Sat Nav or not. I went CM, because no on-board navigation really compares with Google Maps, so there was not point paying extra, when everything you need comes with Android Auto / CarPlay.
    Installation wise, everything was pretty straightforward with CM, albeit not quite as straightforward as an RCD330
